Question about Epson LX-300+ II Matrix Printer
Epson lx 300+II missing lines
I have several of these and the most common prob is the missing lines at the lowest part of the printing. i tried replacing the flexi cable and the head with new and working ones but to no effect.....
i also tried washing the control board for accumulated dirt thinking that this will be the cause of the prob but also, to no avail....
Help Please...
any schematic or service manual of the LX 300+II ESC/P will also be highly appreciated
  • 3 Answers
Hello, my name is alejandro Rey, im from argentina. i have a company who repears exclusively this kind of printers. I im the manager, director and technitian. i will give you the solution for your problem. is not complex, but it requieres some experience with electronic.
the lx 300+2 have a new electronic board. is much more nice to see but, more dificult to meassure with common instruments. the coils from the printerhead still being controlled by a group of 9 transistors. before, in the other boards, the transistors are discrete. you can find them very quicly. now, their are SMD ( mounted and solded in the upper part of the board) and are very very small.
and if you have some transistor open, or burned or killed, you could replace them quickly. now, is difficult to see even the name of them.
but, our friends from epson think in protection and put in series with the transistors one fuse for each. so find the one whos open and replace it. you could use a litle wire, but if you could get the same fuse it will be good. ( i choose the wireç9
you could search for me in the internet in spanish in argentina. type in google "ale rey" and you find me. if you need more help.
electronale@hotmail.com
Posted on Feb 02, 2009
Cara reset LX 300+
mohon dibantu nih... pake printer epson lx-300+II , kalo print dari dokumen bagus , tapi dari browser huruf & angka numpuk. Makasih....
Mar 09, 2012 | Epson LX-300+II Matrix Printer
Epson Status Monitor 3 : Epson LX-300+II ESC/P 'Communication Error' appears after printing successfully ?
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Jan 28, 2011 | Epson LX-300+ II Matrix Printer
Epson LX 300 printer. every line, starting
Try to check your printerhead it could be damage due to over use or old printerhead. Just replace your printerhead to print it normal.
May 29, 2010 | Epson LX-300 Matrix Printer
Can print correcly
plz check all the settings, language setting must be check , after that if the problem not solved then uninstall the driver and again reinstall the printer driver
May 27, 2009 | Epson LX-300+II Matrix Printer
Setting of new paper size from epson lx-300 +II
your solution works fine with me, but the problem is i can't able to save the settings on the printer. so everytime i need to print on that given custom sized paper type, i need to manualy select it from advance tab on printer properties before i have a good print-out..
Anyways,Thank you very much.
Apr 13, 2009 | Epson LX-300+ II Matrix Printer
Epson LX-300+II not printing in draft 10 cpi using visual studio .net
use courier font. it works just as draft font. no problem in VB-6 i hope it will also work with .Net as well.
tell if dont work.
asad khan
justasad@hotmail.com
Oct 27, 2008 | Epson LX-300 Matrix Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300+ II Matrix Printer Logo
528 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
