Question about Sewing Machines
Fix it or Buy a new one
I recently purchased a used singer 241-11 machine
The only piece I received was the machine itself
After looking it over I realized I will need some type of oil tray in order to operate this machine.
My question is simple- is it worth the money to track down the parts I need to complete this machine or should I just go out an buy a new machine?
Thanks
Mitch
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
So, with his background as the owner of the largest, close-tolerance machine shop in America, he spent a year developing the ultimate over bed table. He knew how important features like height, vertical movement, tilt, strength and stability are to delivering a superior product. His invention now allows people to use a laptop or tablet, read and eat comfortably and safely while lying in bed. In fact, the table is so versatile and rugged, it can be used almost anywhere - from the home to hospitals and offices.
https://bestoverbedtable.com/
Posted on Dec 12, 2016
  • 323 Answers
This machine requires a table with a large clutch motor attached under it, usually a 1/2 hp 1800 or 3600 rpm.with a drive belt connecting the machine to the motor.The oil pan sits inside the opening on the bed of the table. To do it completely right you will need a knee lift to control the presser foot and a 6 volt light which plugs into the motor. Oh,yes, you will need the oil pan because the machine is high speed self lubricating (oil pump driven) DRESS MAKING machine. You can use it for upholstery but it will be a constant battle because the largest size needle you can use is size 18 and this is normally not large enough for heavy upholstery thread. It can be done but it is a fight. These parts can be ordered for $200-300. You will have a problem trying to get the oil pan because it is considered an obsolete machine.
If you just want to use it for a hobby or learning machine, forget about the oil pan and sew slowly so it doesn't get a lot of wear. Manually lube it occasionally..
PS See if the seller will take it back.(If you were told it was a complete machine you have a real complaint). This one doesn't even have a reverse. If he will, buy a different machine.Be aware, industrial machines are made for specific operations and they don't interchange very well.
Sewman7
Posted on Sep 08, 2008
My singer outer bobbin holder, three pieces, fell apart. How do I get it back together?
Was told, in the '70's, by a repair guy, that Singer does not provide service beyond 2 yrs of purchase.
I go to ebay, where I find Everything in the world... Suggest you look there. Good luck.
Dec 10, 2017 | Singer Sewing Machines
Singer 9420 bobbin case diagram
Could you check to see if that is the correct model number? I cannot find anything on a Singer 9420.
Dec 22, 2013 | Singer Sewing Machines
Singer touchtronic 2010
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
adjust the top tension one number or letter higher when the stitches
on the bottom are loopy, until the stitches become normal
also change the needle--flat side to the back side of the machine
check with singer website for a manual--some times they have free
pdf downloads
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 2010)
Click search
having a machine serviced once a year is a good idea & makes the machine last longer
and the sewing machine shop will tell you if they can get parts for the machine & if the machine is worth the money to fix it.
I myself have 2 sewing machines, when one is being serviced then I have the other one to use, so I'm not with out a sewing machine when I need one.
good luck
Debbi
May 17, 2012 | Singer Sewing Machines
After sewing about a 2 inch straight stitch, the thread "bunches" in the bobbin case. Where can I buy a new bobbin case? It looks like the bobbin case has a piece broken off the edge and it is...
Take a look on eBay. Also, check out SewVacUSA. They do sell on eBay, too. Search by your machine model. I recently bought a bobbin case through them for my Singer Futura and received it within a week.
Apr 28, 2011 | Singer Sewing Machines
I just recently purchased a Singer "Brilliance"
Go to www.singerco.com and under customer support, you will see instruction manuals, now enter 6180 in the box, and voila, a free copy of your manual to download.
Apr 13, 2011 | Singer Sewing Machines
My sewing machine won't pick up bottom thread. Can i re-time my sewing machine myself?
Return the White product and purchase a Singer. I purchased a White 2308, had the same problem, repairman couldn't fix it, so I purchased a Singer and have had no problems.
I doubt White will let me return the machine since I purchased it some time ago and gave it as a Christmas gift to granddaughters 2008. So, I'm probably out the money I paid for a piece of junk, but I'd rather pay for a better machine and not be so frustrated.
Jan 11, 2009 | White Sewing 2037 Mechanical Sewing...
Need user manual and list of included parts for the Singer 7436
A phone call to a Singer dealer to say you are interested to know which accessories are included with this model will solve the second issue, as to the manual, is the time spent not having one plus the savings you made on original purchase really not worth $15 ?
Sew4Less, or SewUSA may have one, but they will charge....if it is a recent model, the chances of finding a second hand one are remote, and eBay will have machine with manual.
Try the place where you bought it to be certain they don't have the old one kicking around in a dusty corner, or would photocopy one for you ...........a new machine ought to be sold with a manual.
May 29, 2008 | Singer 7436 - INGENUITY
Sewing Machines Logo
347 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
