Question about Sony Ericsson Walkman W810i Cellular Phone
Chager port not proper work
To day i tried to recharge my phone.but phone charger not recognised by phone.whar the reson.
    Brigadier General:
  • 7,752 Answers
You cna take the phone and have the charging port service and clean
Posted on Sep 13, 2008
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Motorola A1200 cell phone battery will not charge with AC chargers
HI,
If your phone is still under warranty the best solution is to get it replaced.The problem is actually with the port of the charger.I mean the hole in which you plug in your charger isn't working properly.Where as your USB port is different and works properly so it charges the battery.So you will have to get this repaired.
Sep 18, 2008 | Motorola Mobility A1200
I need a chager for my kawaski pvs1080 not the power cord the chager to chager the battery or can it be fixed
If it's just the charger, go to best buy or some place that sells laptop chargers and get one that is a multi charger. one with different tips that will select the correct voltage for you...hope this helps you! also try radioshack or another electronics store...they usually have lots of differnt types of chargers that will work.
Jun 21, 2012 | Televison & Video
Chager problem
First check the charger. If charger works, problem is with the charging port of the phone.
Dec 27, 2011 | Cell Phones
My Lg Xenon is not charging properly. It says full battery after i charge it but then when i talk to someone on the phone after about 20 mins it starts beeping saying it has low battery and eventually...
I had a similar problem with a brand new LG Xenon. The battery charger said it was charging but the phone didn't charge. When the battery life on the phone died the phone would not turn on with the charger. I plugged it into my USB port on my laptop and the phone fully charged for real. I got 4 days before I had to recharge it again. Try USB cable to a PC to charge phone. Charger is probably bad. I am getting a replacement and will see if that works.
Oct 21, 2010 | LG Xenon GR500 Cell Phone
The chager part to my phone is not working
Dear Sir\Ma,
Have you tried to change the charger to see whether the charger is the problem and if probably you have done that, then the problem is from the charging port. Two causes may cause this problem 1. Dust or Dirt Try to use a tissue with a pin to clean the charging port, after a well and proper cleaning try to insert the charger to see whether it works, if the phone is still not charging then the problem is that the charging port is damage. 2. Charging port is damage. Get a phone repairer in your area to replace the charging phone for you or go to the phone service center for a repair, they will definitely replace it for you.
Regards
Sep 11, 2010 | Lands Phones
Nokia phone not recharging
Technically, It would be an old battery issue, or the charger itself, try using another charger, if the problem still occurs, maybe it's the battery or your's phone's charger jack had a hardware issue.
Feb 10, 2010 | Nokia Lands Phones
Chager not supported problems
The problem is either from the phone charger, the charging port, the battery, or the phone board.
Therefore, try charging the phone with another battery and charger.
If problem persists after doing as I said, then I would advice that you take the phone to a specialist.
Best wishes.
Dec 18, 2009 | Nokia 3110 Cellular Phone
Tracfone will not charge
try dismantling the phone, keep it disassembled for sumtime... assemble again.. try recharging..
if it still doesnt work, have your charging port checked with an electronics mechanics..
Dec 11, 2009 | Nokia 1100
I dropped my k850i in water. It started gradually working properly after a few days but it wont charge. Everything else works fine. It just doesn't recognise the charger which I know is working fine.
The phone really does need to be taken apart and cleaned properly using PCB cleaner and any IC's which are damaged need to be replaced, the more you put power into it before the damage is cleaned/repaired the more you are risking further damage...
If you havent done phone repairs before, try a decent local phone shop see if they can take a look at it for you.
If you want to try yourself let me know and I can try and find a guide for dissassembly for you, however I have to warn you a lot of the repairs we get everyday where people have done more damage to their phone by trying to repair it themselves, they are usually unrepairable or cost a lot more as more ends up being damaged than the original fault
May 09, 2009 | Cell Phones
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
