Question about Frigidaire GLWS1339CS Top Load Washer
Frigidaire Top Load Washer
Water will not drain out
  • jgrow5 Jan 05, 2009
    jgrow5@yahoo.com
    Have a Frigidaire top load washer FWSB67RGSO washer spins, you can hear to trying to spin the water out but have to put hose to the ground in order to let the water out, I think is the water pump, could be wrong, how do i remove the back of the washer in order to get to the water pump, please email me. Could the pump be blocked with something, I need to remove in order to find out
    Thanks,
  • 750 Answers
Hello vohra_sam
welcome
You said , Water will not drain out
Usually this is the answer
Water in washer does not
drain or drains slowly.
Because drain hose is kinked or clogged.Clean and straighten the drain hose.
let me know, Huuum
Posted on Oct 06, 2008
Frigidaire gallery top load washer is leaking and will not wash big load
Hello msmm50 - Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines or the water valve.
Dec 01, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
The water will run into washer, but will not stay in washer, but not leaking out anywhere
sounds like your drain tube is to low and the water is just running out the drain , the drain tube should be at least a little higher as the washer
Jun 16, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire top loader washer won't drain
The timer has went bad in your front load washer.Thats the reason why the unit is not draining properly. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure. You should go for a replacement.
Thank you !!
May 31, 2010 | Frigidaire ATF6000ES Front Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washing machine top load. troubleshoot
There are levelers at the corners of the unit for levelng - tubs have springs attached to them for righting the tub while working (spinning, agitating) - also if the clothes are evenly distrbuted in tub it will wobble badly during operation.
Leaking is usually from the drain pump especially from the point whwere the hose is attached to the pump
Regards
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Washer does not drain
Possible your drain in the wall is blocked solid; snake it out & pour some water to chk it out
May 07, 2007 | Frigidaire CWS3600AS Top Load Washer
Frigidaire GLWS1339CS Top Load Washer Logo
382 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
