Question about Maytag Neptune MAH5500B Front Load Washer
My machine has a code and is full of water
I did a load of laundry today and went to put it in the dryer and there was a. od code on the digital display. I was wondering if you could help me because my tub was still full of water and the machine just won't do anything. Thank you, Kim
  • Anonymous Sep 25, 2008
    The code on my magtag washer is od and will not start so I have to turn the fuse off at the breaker box and this will reset the washer. It only works once and you have to keep doing it. Help what is the od code stand for?
I have the same od code and the washer will not start, so I turn the machine off at the breaker box and this reset the washer. Only works once and you have to do this everytime to run the machine. Help what is the od code?
Posted on Sep 25, 2008
    Sergeant:
  • 409 Answers
can you provide the full model # and also the full error message?
Posted on Sep 23, 2008
Hi! I have a Maytag Neptune front loading washer machine. On a few occasions I have found a small amount of water in the drum before starting my weekly laundry. Today when I went to start my laundry...
This is symptomatic of a water control valve not closing completely- its no power/fail position is closed.
Whichever it is, hot or cold, needs replacing!
Service call ;-0(
Good luck,
John C
Mar 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Did one load of laundry, went to start a new load and no water is coming out. Tried different water temp, different water levels. If this helps the tag on the upper corner of dryer reads as...
Coin or clothing in the pump
Remove the filter and clean out the pump
You first need to put the oulet hose down into a bucket to drain the water off
Feb 13, 2010 | GE Spacemaker Washer and Dryer Electric...
Water won't drain and washer does nothing
pump is stuck or bad located under washer most are not hard to change
Dec 06, 2009 | Dryers
Push power button nothing happens ?????
Hmm. There should be a hole you can empty the water tank. Please check if it is full of water and try reconnecting it.
Jul 07, 2009 | Kenmore 62602 Electric Dryer
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Mildew/Stagnant water smell in washer
you know, this does happen.
run it on a full cycle, warm, with either of these in solution.
baking soda, at 1/10 concentration
non chlorine bleach, at 1/6 concentration
you most likely need to do this more than once, until your nose is happy.
Also, consider doing this at least once every 200 wash cycles.
essential oils have same effect, and do a nice anti microbial as well.
we did this in commercial laundries all the time, as part of standard health code compliance issues.
Feb 18, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune MAH5500B Front Load Washer Logo
177 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
