Question about E-Machines Computers & Internet
Every day when i turn my computer on, my firewall is turned off, so i turn it back on and make sure it is turned on when i turn the computer back off. today i can't get it to turn on.
    President:
  • 2,961 Answers
If you have an internet security programme, sometimes it will turn off windows firewall and use it's own instead, but you should still be able to turn it back on manually through control panel>windows firewall
Posted on Sep 08, 2008
Message - could not sign in, problem connecting to the server when I tried to set up my apple id for iTunes
Check your internet connection first. If you can browse web fine, then try disabling firewall, see if it connects. MAKE SURE YOU TURN YOUR FIREWALL BACK ON AGAIN AFTERWARDS. If it works, then you need to let the relevant port through the firewall. If that doesn't fix it, post back with more detail about the error messages.
Sep 01, 2013 | Dell Computers & Internet
Why does my computer firewall keep turning itself off?
If you install a antivirus in your computer the computer or the windows firewall automatically gets disabled...so dont worry about it.
Feb 14, 2013 | Acer Aspire Computers & Internet
I keep getting alerts from Mcafee saying my computer is at risk because my firewall is off. I've tried repeatedly to turn it back on, but after a few seconds, it shuts off again.
Goto start then run, type services.msc, scroll through the list for Windows Firewall and ensure the service is "started" and set to Automatic, you can change it by double clicking on it.
May 11, 2011 | Mcafee Computers & Internet
My software for singer futura machine does not install on either computer how can I fix the problem
The problem could be the operating software (Windows XP, Vista, 7), but it sounds most likely like a firewall problem. If you have a firewall program installed like the one that automatically comes on Windows 7, it doesn't allow much to be installed unless you tell it to allow it. Also, Windows 7 needs a patch to allow the Futura software to install and run (available at www.Futura-support.com). Download the patch. When you go to run it, be sure you're off the internet (right click on Windows Explorer icon that appears in the lower left corner of your screen and choose Close Window). Now left click on the Start icon in the lower left corner. Choose "Systems and Security" in the right column, then "Windows Firewall". On the lefthand side will be the second choice of "Turn Windows Firewall On or Off." You're only going to turn the Firewall off long enough to install the Patch and, YES IT IS SAFE! Once you've installed the patch, go immediately back in and turn your firewall back on.
If you use another firewall program (i.e., Norton, McAfee, Computer Associates), you'll have to refer to their Help on how to allow this to install, though their programs will probably ask if you want to install this software rather than just block it. Unless you set Windows 7 firewall to ask you, it just blocks everything.
I hope this is your problem.
Sep 23, 2010 | Singer CE-100 Futura Computerized Sewing...
WebRoot antivirus & antispyware seems to turn off Windows firewa
click on start, then go to control pannel...you should see windows firewall options just double click it,,the open it make sure click on the option button "on (recomended)" this will turn your firewall on permanently
Jun 06, 2010 | Webroot AntiVirus with AntiSpyware &...
Start up will not retain memory for fire wall setting.
Make sure you haven't installed a third-party internet security suite that includes a firewall. You should only use one firewall on your system and some third party firewalls automatically turn the windows firewall off. But your security center should show that you are protected by a firewall, nevertheless.
This behavior can be an indication of malware installed on your computer...
I recommend you go to windows update and make sure you are current with all critical security updates for your system, then go to www.malwarebytes.com and install their AntiMalware software. Scan your system and fix any problems it detects.
Then see if your system retains the firewall settings.
I thought there was a MS knowledge base article on this that had something to do with sp3 and a bug fix but I can;t seem to find it right now...
If I locate it I'll post back with a comment...
In the meantime, if those first two suggestions don't turn anything up, I'd run chkdsk on your system and see if it finds some file corruption.
See this article and this one
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 21, 2009 | Dell Dimension 8400 PC Desktop
The file "hpzrm309.dll" on (unknown) is needed?
You may have to go to"Start", "Control Panel" & then "Windows Firewall" to turn off the firewall then try reinstalling it.
Make sure nothing else is open except perhaps Windows Update if your running Windows and don't forget to go back and turn your firewall back on.
Feb 15, 2009 | HP DeskJet 5150 InkJet Printer
Can not get my printer to print
You may need to reload the software back into the computer , but make sure you uninstall any software for that printer you may have put in before. then shutdown your firewall if you have one, also turn off your antivirus , reinstall the software again , when done reboot the restart the computer, turn back on your firewall , and check all the connections between the PC and printer and try it with a test page. biigg53566
Dec 06, 2008 | HP Computers & Internet
I have Norton Antivirus 2008. I have just purchased the same package again, just in case there was a problem with the first one. Norton's keeps saying that my advance firewall is not on and that the...
This might not be the solution but it might be
try and make sure that nortons firewall is up and running and make sure that the windows firewall is allowing nortons antivirus through goto windows firewall and look to allow nortons through if it is not in the list put it in there
and make sure nortons firewall is allowing widows firewall
and make sure you have auto protect on plz let me know if this helps out
Jul 15, 2008 | Computers & Internet
Turn off firewall in norton 360
If this doesn't work you'll need to tell me the exact version you have but it should.
1)Start Norton 360.
2)Click Tasks & Settings.
3)Click Change Advanced Settings.
4)Click Firewall Protection Settings.
5)Under Firewall, click Off.
6)Click Apply.
7)Under "How long should the firewall remain turned off?" select Until I turn back on, and then click OK.
8)Click Close.
If this fixes your problem please don't forget to rate this as fixed. If you need more help with this just add a comment and I'll be glad to assist you further. Thanks and have a great day.
Apr 22, 2008 | Computers & Internet
Computers & Internet Logo
343 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
