Question about Samsung Blackjack SGH-I607 Smartphone
Black Jack 2, Stuck Enter button
I have a BlackJack 2, I've had for 4 months, the round enter button inside the Large Circle is stuck. I am unable to use that button and I have to use the arrow button to enter. How can I unjam the center button? Thank You
  • 2 more comments
  • Anonymous Oct 14, 2008
    My inner wheel button is jammed also. Is there any other way of fixing the problem?
  • thevictor Oct 24, 2008
    I've used the phone rather heavily for over a year and now my button is broken as well. I have opened the case but am unable to gain access to the center ring. The button is physically jammed in the "pushed in" position and only functions if I press very, very hard on it.
  • Nancy Franklin Nov 13, 2008
    My center button works if I press very hard. Harder than you should have to.
  • Anonymous Nov 21, 2008
    also center enter buttom jammed
    when call warranty department they say its damanaged and that well void the warranty, so had to use insurance at 50$ replacement fee
    so not very happy about finding out im not the only one
    Problem Solver:
  • 7 Answers
My suggestion would be to unscrew the six screws on the back on the device, the two screws on top are covered. Then you could clean all of the components inside the device.
Posted on Sep 08, 2008
Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Brother MFC-440CN InkJet Printer
When I press unlock and the * my blackjack will not unlock
try pressing the function button first this could be the problem your black jack believes that the S button or what ever button the * is on is the other option not the star hit the function button then unlock and the *
Jul 23, 2009 | Samsung BlackJack Smartphone
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
I have a samsung blackjack 2 sgh-i617 and i need to unlock the keypad. it dose not have service on it but i do need to get in it. i have forgot the 4 digt code and now the screen says ''several incorrect...
Take out Battery, Insert Battery. Then hold the up arrow or the top of the round circle and press the power button while holding the up position. It will allow a force flash by pressing 1 and answer Y to continue. It worked for me on my SGH-I617. Best Buy in Denver Andrea gave me the way to unlock, cause my daughter forgot her code to allow keypad dialing. AT&T had no solution and passed me to Samsung and they say it needs to be flashed at a repair center. No way.
Jan 31, 2009 | Lands Phones
Remote is stuck in dvd 3 mode
  1. On your remote, push and hold "Enter"
  2. At the same time, push and hold "2"
  3. Keep them down for about 5 seconds
  4. Your remote should now work with the unit
  5. You can go to the set up menu and change the unit back to DVD3 if you wish, but you'll then need to repeat these steps using the "Enter" and "3" buttons
Oct 08, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Blackjack 2 won't turn on
Hi svstskier,
This is actually a bug in the BlackJack II's firmware. If you power the BlackJack II off, but you're unable to power back on, try removing the battery for about 10 seconds, then reinsert the battery and power back on. The power button should work now.
(At the moment there's no permanent fix for this.)
Does that adequately resolve the issue?
Are you turning the BlackJack II off to conserve battery? While flying? Something else?
Sep 28, 2008 | Samsung BlackJack II Smartphone
How to enter contacts through pc for samsung black jack i 607
There are two ways to enter contacts on the blackjack i 607 on your PC. The first one is outlook and the second one that I would recemend is call Mobile Back-Up. It is a service that AT&T offers it will back your contacts to a server in case you lose your device. It also allows you to create, edit and delete contacts via the internet. The service is $1.99 a month.
Aug 28, 2008 | Samsung Blackjack SGH-I607 Smartphone
How to set time & date on phone
If you subscribe to Caller Display services, the first incoming call will set your phone's date and time automatically. Otherwise, here is how you do it.
1. press Options 2. Press * three times The display shows "Enter time/date?"
You may set both time and date or you may set either of them separately
TO SET BOTH 1. Press # when the display shows "*=Next #=Enter" 2. Wait for each prompt. You will be asked to enter: - the time - am or pm - SAVE - the month - the day, and  - SAVE (Enter the hour, day, and month as two-digit numbers. For example, enter 02:15 for 2:15, 05 for May and 08 for the 8th of the month.)
TO SET ONLY THE DATE 1. Press # when the display shows "*=Next #=Enter" 2. Press * when the time appears 3. Enter the month and day when prompted. 4. Press SAVE
I have a question for you: Can you give me the specs of the AC adapter for this phone (usually written on the adapter)? 1. What is the OUTPUT in volts (V)? 2. What is the OUTPUT in milliamperes (mA)?
3. What is the polarity (i.e. is the + sign in the center of the jack or on the exterior)?
(The wall plug transformer has a diagram depicting two circles with the inner circle representing the center conductor. A line coming from the inner circle will show a minus (-) or a plus(+) symbol to let you know the polarity of the center conductor.)
Mar 30, 2008 | Lands Phones
I am unable to change the time on my phone to reflect the day time savings
You will need to enter programming mode. Here are the directions.
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by setting the switch on the end of a display phone to PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following.
  1. Set switch on end of phone to "PROGRAM" (or push PROGRAM key if you have one)
  2. Dial "0"
  3. Enter year (last 2 digits)
  4. Enter month (01-12)
  5. Enter day (01-31)
  6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.)
  7. Enter Hour (01-12)
  8. Enter Minute (00-59)
  9. Press 0 for AM 1 for PM
  10. Press "AUTO DIAL/STORE" key
  11. Return phone switch to "SET" (or push PROGRAM key if you have one)
Mar 22, 2008 | Panasonic KX-T7730 Corded Phone
How do I set the time and date?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following. 1. Push PROGRAM key 2. Dial "0" 3. Enter year (last 2 digits) 4. Enter month (01-12) 5. Enter day (01-31) 6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.) 7. Enter Hour (01-12) 8. Enter Minute (00-59) 9. Press 0 for AM 1 for PM 10. Press "AUTO DIAL/STORE" key 11. Push PROGRAM key to return to normal mode.
Sep 14, 2007 | Panasonic KX-T7731 Corded Phone
Samsung Blackjack SGH-I607 Smartphone Logo
113 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
