Question about Refrigerators
Maytag Refrigerator Model MSD2454GR
I noticed on the freezer side bottom there is frozen water that has leaked.
Occasionally I get water leaking out onto my floor ,,,not much what could be the problem.
I had this problem and it was due to a poor door seal. Check around the area where the ice is forming to see if there is air leaking from the freezer.
Posted on Sep 28, 2008
Have had this problem also. One problem was that I would toss my spare change on the top of the fridge, and somehow, a coin would end up laying on the seal at the top, preventing the door from closing all the way.
The next time, the wife had put a can of pop in the freezer and forgot about it. In cleaning up the subsequent explosion, I took the racks out and put the wrong one back in the wrong spot, once again keeping the door from closing all the way, but close enough where it wasn't noticable.
The latest leak, according to the repairman on the phone is quite common. For whatever reason, the drain on the inside of the freezer was blocked by ice. The only solution is to defrost the freezer to clear out the ice jam. In my case, turning off the freezer also turns off the cooling in the fridge, so keep the fridge closed as much as possible during the defrost.
Posted on Jun 28, 2010
Water leaks out of freezer bottom same time every day model rsd22
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag side be side model msd2454gr
heatman101
Jul 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Water leaking from underneath the freezer
heatman101
Jun 08, 2010 | Maytag MZD2766GES Side by Side...
Water leaking from front base of freezer
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 29, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaking and freezing at bottom of freezer in side by side Maytag model # msd2454gr refridgerator.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
Apr 25, 2010 | Maytag MSD2454G Side by Side Refrigerator
Ice in the freezer side bottom of my side by side Maytag.
You are having either a defrost problem combined with the defrost drain being frozen over. Need to unplug and remove the rear panel in back of freezer to examine exactly what is happening. Some models like yours have electronic vents that cole if the control becomes defective. . The other possibilities ar the
Adaptive Defrost part number 61005988
The defrost heater with defrost thermostat part number 61006199
Visit our site or click on your model number or part number. I will be here to assist you in your repair, Thanks Sea Breeze
Click Here=> PART NUMBER AND MODEL SEARCH FEATURE
Aug 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Maytag side by side
I have a Maytag side by side MSD2456D and water is running out bottom of freezer door onto floor. There is ice on the freezer coils and there is what looks like a drain tube with a plastic wrapping. I think water is leaking there and freezing on coils until it defrosts ice.Water then appears to run down inside of freezer and out bottom door seal.
Does any one have a suggestion on repair parts. How about owners/repair manual
May 31, 2008 | Maytag MSD2454G Side by Side Refrigerator
Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Oct 19, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
617 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
