Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction in Wand Only, (No suction down below).
I am not getting any suction from below. The brush is turn fine and I have taken off the airway inspection value and there is no blockage. I check the suction up to that point and it works fine. There are no holes in the tube. This vacuum is less than 1 year old. Got any ideas?
  • lisalichy Feb 08, 2009
    Only the tube is working, I have taken all the pipes which are removeable off and checked, they are clear, the band is intact, but only the tube suction is working, any help please?
  • 120 Answers
Check the small hose that is under the machine ( it connects to where the brush roller is ) also you can remove a u shaped tube near the bottom of the machine and also another on the right side of the machine near the bottom as well
Posted on Sep 17, 2008
The wand on this vacuum has suction, but the base unit does not. I have checked all filters, the hose and connections for blockage, etc. The brush is rolling.
some vac's have a small slide that stops te wand suction when the wand sucks the other parts gets none
May 11, 2015 | Vacuums
No suction when I release the wand
Hi there, it's Jack at Dyson.
If your DC28 doesn't seem to have suction through the hose, it's likely you have a blockage in the hose, wand or airway. To check for this, please follow the steps shown in our online Support guide:
This should resolve the issue, but if you need further help after giving this a try we're on hand to offer advice. Just give us a call 1-866-693-9766 (US), or 1-877-397-6622 (CA). If a repair or replacement part is needed, we can also confirm if this is covered under our 5-year warranty.
Oct 12, 2014 | Dyson Dc28 Animal Airmuscle Vacuum 00247
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at
Kind regards
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction & brush will not turn when power
Check your belt. It is broken or stretched out. Replace the belt first. Should be your answer
Nov 09, 2009 | Hoover Elite Rewind Bagless Upright...
No suction
If the belt is stretched, then it can't turn the brush rol under load, if you haven't chenged it in the last 6 months, then I would put a new one one. Also check the dirt inlet by the brush roll for a blockage.
May 30, 2008 | Riccar 8955 Upright Vacuum
Hose has suction but will not stretch when turned on
I have repaired Dyson machines for years & have never come accross this.
The only way you will have trouble extending the hose is if there is a blockage at the bend where you hold the wand could be a coin which when switched on flips accross & blocks oppening.
Is it easy to slide wand from flexi hose with machine switched off ? You will need to remove wand from hose & push broom handle down to the bend & tap coin out.
Jan 08, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
165 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
