My computer doesnot recognize my linksys srx200 WRT54GX2 wireless router during the install procedure. Nor can I get on the internet when connectd to router. Is my router fried or have the setting been zapped.
  • 6,487 Answers
If the router is not being rcognize by the computer when you run the setup CD the router can be bad, first this to do is to try resetting the router by pressing the reset button for about 10 seconds while it power on, then when you run the setup CD make sure the computer is wired to port number 1 of the router and modem is on the internet port, and also check the lighyts there power should not be blinking , and port 1, internet and wireless should be on.
If the power is blinking that is not good it means there's a problem with the router and if the router is still new have it replace from the store and if its less that 3 years go Linksys tech support and have it replace this is the number 800-3267114..
Hope that helps...........
Posted on Sep 08, 2008
    Master:
  • 638 Answers
Its due to the wrong settings normally.pls do check and recorrect ur settings.
    Scholar:
  • 141 Answers
Unplug the router and delete the device in the device manager.
If you don't have the driver disk, download the driver install package from another computer. Use the driver disk to begin the install process and don't plug the device in until prompted by the install software.
    Sergeant:
  • 241 Answers
No it is ok you just need to configure it correctly
  • 1 more comment
  • Jayson Brollini
    Jayson Brollini Sep 08, 2008
    Alfred have you anything else running off the router or is your LapTop the only device trying to connect?
  • Jayson Brollini
    Make sure that you software on your Laptop (intel Pro Set) is what some Wi Fi use. But what ever it may be start from the start.
    .1) software ( intel Pro Wireless) or the wireless software that your network card came with
  • Jayson Brollini
    Make sure that if this your first time doing the connections and that you have no other devices/Computer your Laptop I would try the simple way and use the Network cable and install the software. So in short if you do not a server(PC) then use the cable first to set up everything.
Does it mean my adapter is bad if it just stays lite up green and doesn't flash to try & connect to the internet? I installed everything correctly but it still isn't working. Any ideas? I have a belkin...
The Linksys adapter should have a program you open to find and connect to your router. If not, you can use the Windows Network settings to find your router and connect. Although 54G is a slower speed, they should still connect.
Jan 28, 2018 | Linksys WRT54GX2 Wireless-G Broadband...
Wireless router is working fine to connect to the
Did you install anything new on the computer you are working on? I suggest you to check the version of your printer driver software according to the driver CD you had and reinstall the compatible version of the driver on your computer with a USB cable connected after totally remove the drivers and settings for that printer on your computer now.
Jul 05, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Connectivity issues with my srx200 wireless router
First take the ethernet cable one end should fixed with ur PC/laptop and other end connected to ur modem.finally configure the access page .
Apr 30, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How to install linksys router WRT54GX2 with no CD?
www.retrevo.com › ... › Linksys Wireless Router Manuals
you do not need CD you use a browser and log into router, please check, the manual, it shows you how step by step... download link above.
Mar 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have good internet signal from cable modem and laptop detects router at 46 Mbps but can't access internet wirelessly
  • Is your computer connected to the wireless router
  • If you are able to see the router, maybe you need a security code to access it.
  • disable and enable your wireless on your computer.
Do hope 1 of the above helps.
Aug 15, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
New computer with Vista operating system
You can download the setup wizard here:
http://www.linksysbycisco.com/US/en/support/WRT54GX2/download
Mar 24, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Unable to connect to wireless router
I need more details. Have you called linksys tech support? If linksys cannot help you try this http://technicalsupport.blog.friendster.com/
Feb 12, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Trying to install Linksys wrt54gx2 srx200 on my vista computer
who is your broadband provider? Is this cable or DSL connection? Setting up the router is done via http://192.168.1.1. Leave username blank, password is admin. If you have Cable ISP, then make sure you have "Automatic Configuration-DHCP" selected and MAC address Clone is enabled on Setup > MAC address Clone (click Clone, and Apply). If it's a DSL connection and your broadband provider gave you a username and password, select "PPPoE" for Internet Connecton Type, and enter in your DSL username and password. Next verify if your modem is communicating with the router by going to the Status page and by verifying that you have an Internet IP address. If none, wait for a few minutes and power cycle your modem and router.
Dec 11, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Connecting linksys srx200
It means that the router is not yet configured properly for internet connection. Who is your internet service provider and what is the model or brand of your modem?
Aug 20, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Oct 27, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Computers & Internet Logo
David Payne
David Payne
