Question about Dynex 19 in. LCD Flat-Panel HDTV
Dynex 19" tv
Hi! i have a dynex tv from best buy and like everyone else, cannot get the channels to work. I've done the channel search and can now get channels 2-13, but none others. Also, i went to dynex's website and got the code for my sony universal remote (8043) but have no idea how to input the code. Can anyone help me please? i might should add that i am not the most technology savvy person! thanks!
  • 1 more comment
  • mgrady17 Sep 08, 2008
    unfortunately, there is no option to change anything to cable on the setup screen. also, the instructions on sony's website appeared helpful but did not work. im getting pretty frustrated with all of this! thanks for your help though :)
  • chd971 May 11, 2010
    Do you know where I can get a solid state fuse for the power supply or you can call it inverter. 15amps 240v solid state fuse.
    Thank
    CD.
  • Anonymous Mar 27, 2014
    my dynex tv turns on and then keeps switching betweeen channels 3 and 4. none of the buttons on the side of the tv work. What do i do?
    Scholar:
  • 141 Answers
Go into the setup screen on the TV and set the channel option to CABLE (it is probably set to AIR right now or something).
The website should also have a manual for how to program the remote.
Posted on Sep 08, 2008
Dynex 32" tv cant get regular channels,
How is your TV setup--do you have a cable box, satellite, or basic cable? I would recommend going into the settings and running a channel search.
Press Menu. The on-screen display menu options with Setup highlighted.
Press RIGHT arrow to enter the sub-menu, then press DOWN or UP to highlight AUTO CH SEARCH.
Press ENTER or RIGHT arrow to start the search.
Oct 10, 2013 | Dynex DX-LCD19-09 19 in. LCD TV
Dynex TV picture disappears to snow after a second
I bought this TV and had the exact same problem, I tried everything i could think of and so did Geek Squad but nothing worked. We called Best Buy to see about a return policy and the manager told us that the brands Dynex and Insignia do not work with certain cable companies, one being Comcast. Call Best Buy and ask if your cable company will work with the brand. My suggestions are to either return the TV and search for a new one, I did this, OR you could take a DVD/VCR player and connect the cable from your wall to the DVD/VCR player. Then use the red, yellow, and white wires to connect the TV to the DVD/VCR player. Put your TV on the proper input and cable will work fine, because you will see the picture from the player not directly from your TV. I hope this helps, if you need any further information just ask.
Apr 15, 2010 | Televison & Video
How do i cahange my reception From analog to digital?
The Dynex LCD-19-09 19in LCD Tv has a digitial tuner in it already. I would recommend doing a channel scan and make sure it is on the "Antenna" setting instead of "Cable" and let it scan for channels. You will see all the analog channels like "7", "12" if they are still broadcasting, however, if you can pick up the digital channels, it will look more like "7-1" or 12-1; 12-2 etc.". To get to this, push the "Menu" button on the Dynex remote, then arrow down twice to TV, then push the right arrow and make sure it is set at Antenna and do a channel scan. Should get you whatever digital channels are available. If the digital antenna is not strong enough, you will need to get the digital one at Wal-Mart as previously suggested and hope that will convert the analog channels in your area.
Jun 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Trying to program the tv with the direct tv remote
Not out of luck, Dynex.com says to use codes from other model of televisions. The way I did it (I have a DirecTV remote as well) is just did a code search till I found which one turned it off. The only thing it won't do is change which input you use, but the menu, volume and channel controls all work fine.
Mar 27, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Swtiching to Digital tv
If you are connected to Cable TV service you are probably already setup, but here are a few things to check for.
  1. From the Menu, make sure the tuning band is set to Cable and not to Air or Antenna.
  2. From the Menu perform an Auto Channel Search.
That should be all you need to do.
Now if you want the best High Definition picture, believe it or not you will need an Antenna, depending on your location you will be able to pick up OTA (over the air) channels in the purest form.
I can help you with this also, let me know. Lone99star Please rate this solution.
Feb 17, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Dec 30, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
Oct 03, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Only channels 2-13 show on new Dynex 19" LCD TV
You'll need to find the Cable/Antenna setup and change it from Antenna to Cable. Sometimes the setting you want is called CATV.
Aug 12, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Jul 28, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 19 in. LCD Flat-Panel HDTV Logo
544 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
