The Virtual Cable Tester feature verifies the link status on each port. It will determine if link activity is active on each of the ports and also verify if the cable is faulty. The following routers have VCT support: DI-604 rev. E1 DI-614+ rev. B1 (Single Antenna) Step 1 Click on the Tools tab and go to Cable Test. This will display the link status for each of your ports. Step 2 Click on the Refresh button to refresh the link status to the LAN devices on the network.
A P0012 DTC trouble code may be caused by one or more of the following:
- Incorrect camshaft timing
- Wiring problems (harness/wiring) in intake timing control valve control solenoid system
- Continuous oil flow to VCT piston chamber
- Failed timing valve control solenoid (stuck open)
On Ford, the VCT solenoid is located at top of cylinder head underneath the valve cover and goes around one camshaft. You will need to remove the valve cover, the timing cover, then remove the timing belt, the camshaft sprockets, and finally the camshafts to remove the vct solenoid as it goes around the camshaft. You can use 2001-2003 models with same engine.
VCT or Variable Cam Timing solenoid is a device used in modern engines to change camshaft position timing in relevance to engine speed and engine timing allowing the engine to produce more horsepower without adding excessive overlap to the camshaft design.
The way the VCT Solenoid works is as follows:
The VCT solenoid works with oil pressure, it receives a signal from the ECM when the camshaft needs to be rotated either in the advanced mode or ******** mode depending on engine load and speed.The VCT solenoid is able to accomplish that by altering the oil flow in the passages that lead to the cam phaser(s), there are passages to advance the valve timing ( open the valves earlier), and passages that direct the oil to ****** the valve timing ( open them later)
The purpose of the VCT or Variable Cam Timing system is to allow the engine to move larger volumes of air in and out of the cylinders to generate maximum horsepower.
Vehicles with DOHC ( Dual Overhead Cam ) engines usually have two VCT solenoids mounted in each cylinder head, one for each camshaft, allowing the Engine Control Computer to activate each VCT timing mechanism in each Camshaft separately.
NOTE: The Cam phaser is mounted on the front of the camshaft(s) it is driven by the engine's timing chain or timing belt depending on the engine's design.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
