Question about Canon IMAGERUNNER 6570 Copier
Canon iR6570 waste toner
How do I replace the waste toner bottle in Canon iR6570. Like where is it?
  • 1 more comment
  • Anonymous Mar 21, 2014
    cannot copy or send
  • Anonymous Mar 26, 2014
    canon IR6570 E821-0001. help me please what the solution.
    I got Error E821-0001 on IR6570. show me the service manual please.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Look on the right rear of the machine, there should be a door with 2-4 screws. A big white plastic container should be there, remove dump toner and seal bag, replace. Make sure it is sitting properly, it uses a weight system.
Posted on Sep 08, 2008
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
I have canon ir 6570 continueing errod code e0013 solution
This is the standard Canon code for waste toner feed screw is locked. Most likely someone reset the waste toner counter and the waste toner has backed up in the auger screw. You should first empy the waste toner bottle located on the right side lower right. Remove the two screws and empty the bottle you find. You may even have to remove all the associated covers motors and circuit boards to get to the waste toner system. You will have to either clear out the auger tube, or replace the whole assembly. Check for broken parts, bound up screw, fused toner, etc. I've done this a couple of times and it's not fun. I try to make sure that I empty the bottle at every 1 million copy mark just so this doesn't happen again. Good Luck.
I have problem canon ir6570 e025-003?please help me,
This is an error code for the connection of the toner bottle motor at power up is not detected. Did you recently ahve the hopper assembly off? Maybe this connection was forgotten. Check. The motor itself may have to be replaced.
Nov 01, 2010 | Canon imageRUNNER 5570 Copier
Error is E000019-0000
Let the front of the canon copier/image runner iR 3300 as a referrence, waste toner bottle is located under neath the small cover of size 15 cmsX 30 cms and this small cover is located at the extremely lower left corner of the copier/image runner iR3300.This small cover will fixed with one and only one screw at the upper/top right corner of the small cover. Un screw this small cover and remove the small cover along with the attached screw and kept aside. Under neath this small cover there will be a big plastic bottle which is called as the waste toner collection bottle. The capacity of this bottle may be 11/2 kgs to 2 kgs. When this waste toner bottle was filled up , a message will be appeared on the screen that ' replace the waste toner collection bottle'. Even after the this message the copier/image runner may work properly. If the message of error code E000019-0000 appeared on the screen this waste toner bottle may be filled completly. Then the coper will stops to work. Then gently remove this waste toner collection bottle slowly and empty the waste toner bottle which was filled up with waste toner within the plastic bag. Wash this waste toner bottle with soft water 2 or 3 times and there after with soft detergent washing powder , so that no stains of waste toner or any type of stains may be completly removed. Please don't try to remove the water particles with cloth or any thing Or don't try to remove the water particles with Hot hair dryer. After washing the waste toner bottle , dry this with the air coming from cealing fan or with cold hair dryer. After the waste toner bottle was completly dried withj the cold air replace the this bottle in the original place. Before replacing the waste toner bottle in its original position clean the place of waste toner base / holder -up , down, left & right with the clean and soft cloth which is under neath the small cover. Hurray ! your problem will be solved completly without any expenditure but you may expected to take time with patience.
Sep 22, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Sir ; i have a canon ir6570 machine,it was coming an error code e025-001<br />what is the problem?<br />pls give me a solurion.<br />thank u
the waste toner bottle is stuck int he hopper assembly
try removing the toner bottle and reseating it
if it doesn't work then you blew a fuse on the dc controller board
Aug 21, 2010 | Canon IMAGERUNNER 6570 Copier
(6981A002AA) for imagerunner 2200, 2800, 3300 Print Server: I have also facing the same problem of Error code ...
So, you need to do next:
Because of statics and plastic bottle, the toner is collected on bottle neck, where is two circles. Even if bottle isnt full but the neck of bottle is dirty the error will occure.
Clean the neck with dry cloath, and then with some antistatic detergent, this will take care of the bottle.
But more permanent solution is to disconnect the waste toner sensor. You will see it above the waste toner bottle.Its a white connector with wires. Pull it out.
But then you need to take a very good care of amount of waste toner in bottle, because if it gets too full it could broke the waste toner gears. So that means that you must every time when you replace the drum, empty the bottle too.
May 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Where is the waste toner bottle located?
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
Jul 09, 2009 | Canon imageRUNNER 2000 Copier
I have a Canon ImageRunner C3170U/C3170I
When you open the front cover,there is a transperant bottle with waste toner remove the bottle and remove the waste toner from the bottle.There is aslso a small clear transperant plastic holder that detect the level of the waste toner.Use a no2 star skrewdriver and remove it.Clean it and put it back.And reinstall the waste toner.
Jun 16, 2009 | Canon imageRUNNER C3170I Color Copier
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
Canon 2200 error code 000019-0000
This error code means that the waste toner bottle is full. Most likely it is not full, the waste toner bottle neck gets some waste toner on it and it blocks the sensor.... It is a bad design by Canon. The waste toner bottle is on the Left side of the copier, toward the rear of the copier. The cover is held in by one screw, the cover comes off and the Waste Toner Bottle is inside. Turn the copier OFF by the Main Power Switch on the Right side of the copier. Carefully, dump the waste toner out in a plastic bag. Hopefully, without any holes in it. Wipe OFF all the toner OFF the neck of the bottle. You will see what looks like a DOT on each side of the neck.Make sure the inside and out side is clean. Reinstall the bottle and cover and then turn the Main power ON and the Code should be gone. Good Luck....
Mar 29, 2009 | Canon imageRUNNER 2200
1,353 people viewed this question
old marine
old marine
