Question about D-Link Express EtherNetwork DI-604 Router
Question What will happen if I telnet from the LAN side into my DI-604 and enter 40 to 100 return characters?
    Novelist:
    Scholar:
  • 128 Answers
The device will lock-out inbound and outbound transmission until you physically reset the unit. It is suggested that if you are doing this, STOP. If someone is getting onto your LAN side without permission you need to increase your network security methods. Using the MAC filter under Advanced > Filters can be the first and last step towards stopping annoying intruders.
Posted on Feb 16, 2006
Where can i get the driver for Di-604 for a win 7 64bit OS
Routers don't need drivers. You connect to it via LAN using a LAN cable.
For further instructions, check manual at http://www.netwood.net/support/manuals/D-Link_DI-604_manual.pdf
Jan 14, 2011 | D-Link DI-604 - 4-Port Broadband Router [...
I have connected my DI-104 Router to my Motorola Surfboard modem and have two LAN cables to two other computers. However, neither computers recognize the connection. I have my main computer connected via...
Turn the router off.
Use an Ethernet cable to connect one computer to one of the 4 'LAN' ports on the computer.
Turn the router on.
Click Start
Click Run
Type CMD
Press ENTER
Enter IPCONFIG /RENEW
Press ENTER
Look for lines of output like:
IP Address. . . . . . . . . . . . : 192.168.40.150
Default Gateway . . . . . . . . . : 192.168.40.1
Open Internet Explorer.
Enter: http://192.168.40.1 (if that's the IP-address on your computer for the 'Default Gateway').
You should see a D-LINK "login" web-page.
Try an ID of 'admin' and a 'blank" password.
Once logged-in, you can check the router-settings, and then "configure" it.
Jul 17, 2010 | D-Link Express EtherNetwork DI-604 Router
Have 604 router. all of a sudden only two computers can be active through the router and it does not allow the other two to work. things were working fine with all computers getting browser access... now...
On the computers that are not getting Internet access, check the LAN cables to the router. Does the Link LEDs on the router for these computers are ON?
If the LED lights are off then the LAN cable and/or network cards are faulty.
Check Device Manager on these computers to see if the LAN card is working and enabled. If not re-install the LAN drivers. If the driver installation cannot detect the LAN card then most likely the LAN card is faulty and needs replacing.
Get back to me with the results of these tests and I can advise what to do next.
Nov 16, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Cant share internet using a router
Hi There, what model of dlink router do you have?
Also, Or just check the ports you have in your router, the internet should be connected to the WAN port and the switch and/or computers to the LAN port(s).
If the router is new by default you should be able to access internet by plug everything the way I told you.
Also, by default the router ip address should be 192.168.1.1, type that into your web browser address bar, then you will have access to the router admin web page were you can see the status page, there will tell you if you have or not access to Internet really. Maybe the problem is that the router have no access internet access at all.
Mar 12, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D-link DI-604 installing
The 192.168.0.1 was probably changed when it was first set up. To return it to default settings take a paper clip and insert it in the reset hole in the back of the router.
Give it a few moments to reboot and the 192.168.0.1 address should work.
Oct 04, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-Link DI-604 Router can be use in Wireless Broadband?
You can use any wireless access point. If you would like to stay with Dlink, you could try the DWL-2100AP. You would just need to plug it in to an open port on your router.
Dec 28, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
No response from the DI-604 D-Link Router
The cable must be of parrallel type......(not cross)... connecting router and the modem or PC...
Dec 23, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
Nortel Extranet VPN using ESP IPSec
Step 1 Go into the web-based configuration on the router (enter 192.168.0.1 in your web brower). Enter username (admin) and password (blank). Step 2 Click on Advanced at the top and then click on Applications on the left side. Step 3 Check Enable Step 4 Enter a name (i.e. Nortel). Step 5 Enter 500 for Trigger Port (500 - 500). Step 6 Select Both for Trigger Type. Step 7 Enter 500 for Public Port. Step 8 Select Both for Public Type. Step 9 Click Apply and then click on Continue when prompted.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Open Questions:
How to select best payroll software in India, Dubai, UAE, Qatar, Oman Using a Payroll Software in Dubai or a Payroll Management Software in UAE will definitely save you time and money. This will allow you to focus on your business. You don't have to be a Payroll Processing expert to use the software. You will need to buy an end-to-end system incorporating your company requirements. Following are the eight components that are going to help you discover how you can choose the best payroll solution. Offline or Online Payroll: You can choose from two types of payroll software - offline or online software. Choosing one solely depends on your business type, your working mode, and preference. Offline payroll is installed locally on your computer. You won't need an internet connection to access your payroll data. With offline payroll, you will have a flat purchase price, and only pay for future upgrades. If your PC/laptop is destroyed, you will not be able to access your Payroll Processing, Payroll Hold, Pay slip, Trail Payroll, Payroll Reports data. Online payroll, also called as cloud-based payroll software, help you to access it anywhere and anytime. You just need an internet connection and your login credentials. This type if HRMS Software in Dubai, UAE, and/or Abudhabi is advantageous if you are always travelling. With cloud-based payroll software, you get to retrieve your data from many devices. You can log in on a computer or on your mobile/tablet. Initial/Recurring Costs: How much do payroll software cost in Dubai, UAE, and/or Abudhabi? As a business proprietor or company's management, you most probably are not looking to spend money to buy whatever is promoted to you. You are looking for affordable services which get the tasks completed. When determining on the HRMS Software in Dubai, UAE, and/or Abudhabi, the cost is one of the main factors. The Business Software Provider in Dubai, UAE, and/or Abudhabi should not charge you hidden costs/fees. You might have overlooked them during the initial HR Payroll Software cost examination. You don't want to quickly select a Payroll Solutions provider and later notice extra costs you didn't know of. There are different pricing models. Always read the contract and understand the full extent of what is included. Add-ons or Modules: Cost is an important factor, but you want the Payroll Management Software to perform to your requirements. Every business is different. The Best Payroll System for Dubai, UAE, and/or Abudhabi should be able to incorporate your business requirements. The Best HRMS Software in UAE should not be different from the Best Payroll Software for Dubai. Service and Support: When using a payroll system, you have got to have control over it. You need to feel comfortable when you get questions. A payroll system should have effective support to help its users. Most payroll solutions have customer support consultants. Most payroll software vendors help in setting up your system. Support is the second most important item in your checklist, compare support provide by different vendors. Your Payroll Management Software vendor should provide phone and/or online support. Learning Curve: Choosing a payroll solution that is easy to understand and use is the third most important thing while selecting a payroll system. Many payroll solutions need some level of prior working knowledge to use them. Take a trial so that you are able learn to use the payroll solution before buying it. Purchasing the Best HRMS Software involves a low learning curve; this results in money and time savings. Trial Period: Most payroll solutions in Dubai, UAE, and/or Abudhabi have trial periods to let the user get a feel of the software. A trial period allows you to gauge precisely what you are buying. Check the payroll solution you are contemplating to see if it has a trial period or not. This lets you determine whether the Payroll Management Software is the right one for you. Security: Security is the third major factor when selecting a HR Payroll Software in Dubai, UAE, and/or Abudhabi. You do not want someone to gain unauthorized access to your employees' personal data? It is a nightmare for management and workers. Always ask how the Payroll vendor secures the data. Any payroll solution you choose should have high-grade encryption, as is bank software. Contract: Ascertain if the Payroll Solution has a contract or not. Payroll solutions don't necessarily have one. Before selecting a HR Payroll Solution, check if there is one. Before entering into one, make sure the HRMS Software fits all your requirements. Sometimes there might be an early termination cost. You should choose payroll software that has no contract. You will be able to cancel the vendor and select another one when needed. You need to make sure that the Payroll Software has Payroll Processing, Payroll Hold, Payslip, Trail Payroll, Payroll Reports function in it. Select the best Business Software Provider in Dubai, UAE, and/or Abudhabi, and that they provide Employee Attendance and Leave Tracking as a built-in function. You should also make sure that Payroll Solutions Portal works in Dubai, UAE, and/or Abudhabi. The above points are the positives and negatives when choosing a Payroll Management Software in Dubai, UAE, and/or Abudhabi. Always make sure it fits your requirements.
Jan 16, 2019 | Major Computers & Internet
See all D-Link Express EtherNetwork DI-604 Router Questions
D-Link Express EtherNetwork DI-604 Router Logo
42 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
