Question about iLO 3200 32 in. LCD Television
Ilo 32 lcd
Wont turn on ,the ligth red do not turn green 32 in ilo wont turn on, red stand by light on, wont turn green powered
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Posted on Sep 10, 2008
ILO DPD4210, no picture or sound. It appears to be stuck in stand by mode. The LED lights are solid Green or Red. It just stopped showing the picture and sound. Any suggestions of what might be the...
Sounds like an ordinary power supply failure. You just have to desolder and semiconductors that are bolted to heat-sinks and or look for electrolytic capacitors that are bulged or not the correct reading. A lightning strike or power surge could have blown a thermistor.
Oct 17, 2013 | iLO 3200 32 in. LCD Television
ILO 32" TV (4 yrs old) seems to have no power. The power light is out (not green or red). We have checked the power chord, etc and that's not the problem..
the problem goes beyond chords. most lightly its the internal power supply that failed, this part is build in such a way that its to much to repair. solution is to replace power supply
Apr 27, 2010 | iLO 3200 32 in. LCD Television
Ilo 32 inch LCD tv will not turn on
replace bad cap in the power supply the top will be put up
Aug 28, 2009 | iLO 3200 32 in. LCD Television
32 inch ilo LCD wont turn on or anything, no red light or green.
Hi there! You may have had a power surge. Most of these panels are not fitted with a manual on/off switch which can protect it from spikes. If you switch it off using the remote, it is still in danger of getting damaged via the power source. I would personally start with the fuse. If this fails and you are not in the know how of repairing electronics then refer to a repairer. Beware of High Current!!! Unplug from mains and replace fuse carefully with the same rating and refrain from touching anything else as the main capacitor may still be charged. Stand back when you switch on, especially your face as a fuse may explode and send pieces of glass flying. Bset Wishes and Good Luck, JUS004
Aug 22, 2009 | iLO 3200 32 in. LCD Television
Ilo 32 lcd
Here is the e-mail of a class action attorney investigating a claim against iLO.
Matthew D. Schelkopf [mds@chimicles.com]
They have had my TV for 5 months! There are many more people who bought one of these POS’s.
Jul 06, 2008 | iLO 3200 32 in. LCD Television
Will not work
one of the pcb boards has suffered a failure you need a service tech to determine what board has failed and what the cost is to replace it
May 08, 2008 | iLO 3200 32 in. LCD Television
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Ilo-27 lcd
I CAN,T GET IT TO CHANGE CHANNELS. I DON,T HAVE THE ORIGINAL REMOTE SO I HAVE TO USE A UNIVERSAL AND IT WON,T PROGRAM.
Jan 13, 2008 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
448 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
