After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
SOURCE: need to reset
just keep pressing the cancel button for 10 seconds,,, it will start blinking,, then reset it to your desired point
SOURCE: conair ww17 scale measures in kg not lb.
There is a switch on the bottom of the scale on mine to use either lb. or kg.
SOURCE: change scale from kg to lbs
Ok i Just figured it out my self with no manual. When you put new batteries in your scales the unit will be shut off. Press and hold the select button for 5 seconds and then it will show LBS or KG and you will be able to change your weight at that time. Hope this helps.
Please log on to .Eng Net tools. You an download a free software that can find great use to convert all your requirements.
the link is as ; http://www.engnetglobal.com/
also 1 KG= 2.20- lbs ( 2.65lbs in another system)
Please vote if helpful
