Question about Roper RS22AQXKQ Side by Side Refrigerator
Where is the water filter on a 1997 side by side Roper
I need to know where the water filter is and how to replace it. Mine is a model RS22AQXFN00. The ice maker is filling very slow and the water comes out slow too.
  • lphipps37 Sep 08, 2008
    No. It was in my house when I bought the house.
    Lynne
  • 2,071 Answers
Filters located in the base grille of your refrigerator
These filters have a reusable knob. Hold the knob and make a 1/4 turn to the left. Pull the old filter out. Replace the knob on the new filter from PartSelect.com. Once the new filter is inserted, turn the knob a 1/4 turn to the right to lock it into place.
Filters with a push-button filter
This filter is located in the base grille. Press the large button next to the filter. The filter will pop out so you can grasp it. Pull the filter out and replace it with a new one from PartSelect.com. Push the filter back in until it clicks. Remember to take the cap off of the old filter and put it on the new replacement filter.
Slide out filter.
The cartridge is located in the front of the refrigerator compartment. Open the compartment and remove the filter. Replace with the new filter from PartSelect.com and slide the compartment back into place.
Filters with housings
Some filters are located in a round plastic housing. You may need a wrench if the filter was put in very tight. Once the housing is removed replace the filter inside with a new one from PartSelect.com and reinsert the housing and new filter in your refrigerator.
**It is very important for you to flush a couple of gallons of water through your new filter. Most refrigerator water filters are made of carbon, and some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water.**
Find your water filter
Hope this may help you;
Regards,
VOTIT
Posted on Sep 08, 2008
  • 3,037 Answers
It is located in the grill below the freezer door
    Sergeant:
  • 264 Answers
Do you have a manual for the refrigerator to check he same
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
Does my roper fridge have a water filter? model rs22aqxmq01 serial st26598
Not all fridges with water dispensers have integral filters. Several have an external in line filter fitted to the supply pipe.
Jul 13, 2014 | Roper RS22AQXKQ Side by Side Refrigerator
Cold water hose connection filter clogged up - how to clean out
Are you referring to the conical shaped screen in the end of the hose that connects to the water supply? If so, it can be removed using a sharp pointed instrument such as a small screwdriver. Then it can be cleaned by flushing it from the back side.
Sep 12, 2012 | Refrigerators
Water leaking from water filter/housing
How old is the filter and are you using the correct filter? After markets don't seal well, and an old filter can leak.
You can remove the filter and use the dispenser to determine if just the filter is the issue, the housing has a by-pass system and works without a filter in it, just would filter water without a filter.
Give that a try, let me know if you need more help.
Aug 28, 2011 | Roper RS25AEXLQ Side by Side Refrigerator
I have a side by side refrigerator & the water filter light is red & the filter needs to be changed. The refrigerator was manufactured 11/04 model # ED26HEXNQ00. I don't know what kind of...
The light will just come on based on time not on if the filter is really need to be changed, you can push and hold the button to reset it, and another six months or so it will light up again. I do not have the same model as you, but mine is in side the ref. top right side, others are on the water line in back.
I have two filters before the refrigerator on mine still go's off I just reset it. If the filter is really needing to be replaced your water would slow to a trickle.
Jun 30, 2011 | Whirlpool Refrigerators
Bad tasting water
Do not use a steel or plastic braided supply line. They make the ice taste bad.
Dec 29, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
We have a jenn-air jfc2087hrs (french door model) and the water pressure from the internal water dispenser is very low. the line has plenty of pressure.
If your ice maker is making full size cubes then it should one of 2 problems.
The water valve on the bottom back of the machine is a dual valve. One side feeds the ice maker, the other side feeds the water supply.
1. The dual water valve. is going bad. The water side is malfunctioning.
The dual valve must be replaced.
2. Your model should have filters for the water dispenser, and need replaced.
Try changing the filters first.
Oct 04, 2009 | Jenn-Air JFC2087HRS Side by Side...
Roper RS22AQXKQ Side by Side Refrigerator Logo
578 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
