Question about Tascam 2488 Portastudio Multitrack Recorder System
Plugging in keyboard
I have 2488 portastudio my old portastudio is a old 4 channel cassette recorder I'm lost at what I came do with my new 2488 One question I have is
on my old recorder I plugged the recorder in the headphone output jack
and used this method for my keyboard tracks on the recorder
Can this be done plugging into the h plug.Also it has a midi output on the keyboard can I just use the midi output on the keyboard and plug that directly into the midi input and direct it at any channel on the 2488 This is a new world for me I love recording I'm trying to come up to the 21 century
  • oneriver Sep 12, 2008
    Hello, i have a keyboard Fantom-S, i am not sure where to plug it in. I have two left and right connectors to plug in, where do they plug in please? Thankyou
Proceedure to record a key board track to the 2488neo
Posted on Aug 08, 2011
    Novelist:
  • 189 Answers
The 2488 actually becomes your mixer and recorder. So to record your keyboard, you would take the stereo outs from the keyboard and run those into two inputs on the 2488. Then you assign those two inputs to two channel strips on the 2488 and you can play through the 2488's monitors, and then choose to record the stereo output of your keyboard as an overdub while listening to other tracks but just recording the keyboard in stereo on the two channel strips that you've assigned those inputs to.
Hope this helps.
bd.
Posted on Sep 15, 2008
    Scholar:
  • 141 Answers
MIDI only carries digital information, not audio. Midi is used to communicate patch settings and note value information. If you want the recording to know the note value, then you should use midi. This is useful if you want to do things like adding rythm tracks, etc.
If your keyboard has audio/line out (as opposed to headphone out), use that, as it is matched much better in impedance. If it doesn't have audio/line out, then you can use the headphone jack, but you will have to turn the attenuation way down because the headphone jack impedance is much higher. This will tend to distort on the recording if you are not careful.
The first thing to know about digital recording is that distortion is much more of a problem. I won't get into the theory of this, just know that impedance mismatching is more of a problem with digital.
Posted on Sep 08, 2008
MY PC wont recognize my Tascam Portastudio device2488, i have Vista
Tascam 2488:
I use Vista and my 2488 MK1.
When you plug in the USB cable from the 2488 into your Vista PC, Vista will always say 'not recognised'.
You do not need any PC drivers for the 2488. On the Tascam 2488, go to 'Menu', then 'Disk', then 'USB Open/Close', then click 'Yes'.
On your PC the 2488 will appear as a new hard drive in the 'Computer' folder, called HDR2488.
You'll see three folders in there: WAVE, SMF and BACKUP.
Use the WAVE folder to import and export WAV files, the SMF folder to import midi files to the 2488, and the BACKUP folder is where you can import and export Backup files to and from the 2488.
Hope this helps!
May 09, 2012 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
Recently purchased the Tascam 2488 Neo Digital/Microphone Effects
Assuming you have your mic plugged in properly and all is working well save for this one issue, do as follows: press the SELECT button on the track/channel which has the mic on it. Then press the SEND button over to the right of all the tracks. The button is right under the EQ button. After you press the SEND button, a screen opens up and you can send reverb to that channel/track...as much as you want. I hope this helps.
Feb 17, 2010 | Tascam 2488 Portastudio Multitrack...
My husband and I just purchased tascam 2488 portastudio, we are truly novice and need help with figuring out what cords are needed to connect the mics we have to the tascam. We would also like to know is...
If your mics are XLR (a hole on the bottom of the mic with three pins visible in it) you will need one of these for each mic, plugged into one of the four channels on the tascam that has an XLR connection (which will be the female version of the connection on the bottom of your mic). If your mics have a 1/4-inch connection, you can use the 1/4-inch connection on any channel on the tascam. For the stereo connection, you will need one of these of sufficient length to convert the RCA output from your stereo to the 1/4-inch input on your Tascam. Find "Tape Out" or "AUX Out" on your stereo and plug in the RCA side of the cable there (note which color you use for R and L). Use the 1/4" end of the cable to connect to two available channels on your mixer. Use the Pan knob to pan the left channel to the left and the right channel to the right, and voila! Hope this helps, and good luck!
Nov 13, 2009 | Tascam 2488 Portastudio Multitrack...
Connect yamaha keyboard to tascam 2488 MKII
There are 8 inputs on the back. 4 of them support XLR type microphone connections, but also double as 1/4 inch and the remaining four are just 1/4 inch. These are all line level inputs and you can use any of them for a keyboard hookup. Typically you might leave the XLR inputs (A thru D) available for mics and take the next two (E and F) to use from your keyboards L and R outputs. Then just assign those inputs to two adjacent channels (tracks) or one of the stereo pairs, turn up the input levels for those inputs and the faders for those tracks and you'll be able to hear the keyboard playing through the 2488 (or whatever monitors/or stereo you have hooked up to it for monitoring). To record the keyboard simply arm whatever tracks you have those inputs assigned to for recording and record away.
bd.
Oct 30, 2008 | Tascam 2488 Portastudio Multitrack...
To record the eight inputs onto 8 separate tracks at once simply plug your mics or other audio sources into the mic inputs (only 4 can be powered, A-E) and then assign each input to a separate track by pressing the input button which corresponds to one input and then the select button for the desired target track at the same time. Do this for all eight inputs and their target tracks. Then arm all eight tracks to record by pressing the record buttons on each (the red lights will come on). Then when you press play and record in the transport section (or use punch operations) you will record all eight inputs to all eight tracks at the same time.
Good luck.
bd.
Jul 06, 2008 | Tascam 2488 Portastudio Multitrack...
Tracks 13/14 etc...
As far as I'm aware there is no way to record to just one of the stereo paired tracks (channels) on the 2488. There are individual mono tracks underneath those channels, but they are controlled with one fader and can only be recorded to in stereo. They are designed to be used for recording stereo sources and stereo bounces. You can however record to any of tracks 1 to 12 and then move (assign) that track to say track (channel) 13 or you can clone any single track to any other track (channel).
The term track can be misleading on the 2488. It might be easier to refer to the 1-24 fader controlled 'tracks' on the 2488 as 'channel strips' and refer to each of the 250 virtual 'tracks' on the 2488 as 'tracks'. You can assign any of the 250 virtual tracks on the 2488 to any of the channel strips. So you have 250 tracks available, but can only work with 24 of them at a time. The stereo pairs just offer some extra convenience when working in stereo. They allow you to control the volume of two tracks with one fader making working with stereo easier.
Channels 1 and 2, 3 and 4, 4 and 6, ...11 and 12 can also be linked as stereo pairs and will be controlled with the fader of the odd numbered (first) track when linked.
Cheers,
bd
Jul 03, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488mkll echo
I just bought a 2488mkll .I have a keyboard. On my old portastudio
I had to us the headphone output of the keyboard to plug into the portastudio for a signal can I do this with 2488mkll. Also the keyboard has a midi output I'm not familiar with midi cables it's a 5 pin midi can I just plug the midi output of the keyboard into the 2488mkll input or do I need something more?
May 13, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
138 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
