Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Loud noise our refrigerator makes a loud banging noise and vibrates. It does this at the same time every morning around 4 am
  • cathybraud Nov 23, 2008
    when you use the water on the front door it makes a laboring sound and the water trikles out. now icemaker has started to make the same sound when the water is filling the tray.
    Problem Solver:
  • 5 Answers
The vibrating sound you hear could be due to "water hammer" when the fill valve tries to close against high water line pressure. I had that problem and solved it by putting a small valve in the line to the ice maker and closing it little by little until the vibrating went away. You know, the banging could also be water hammer. It only happens at night when the entire neighborhood is asleep and the water pressure is at its highest. You need to check this out because water hammer can be very destructive to the plumbing and the valve.
Posted on Oct 08, 2008
Why is ice maker loud when filling tray and water flow slows down?
perhaps you need to leave it turned on all the time . thry were not made to be run as a part time unit .
Apr 04, 2016 | Refrigerators
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
The compressor is making a loud noise
If you are sure the noise is coming from the compressor.You need to call a tech. to check the unit out.
Jan 31, 2012 | True Deli-Cases TSID-72-4-L Refrigerator
Right before the refrigerator starts running, the unit vibrates, makes a clicking noise, and then a series of loud banging noises that sound like hitting a ping pong ball against a table. Then it gets...
This is just a WAG but it doesn't sound like a compressor problem to me. The clicking could be the start relay, which could be a combination of either the start relay or start capacitor.
The vibration and banging is probably the shock mounts that the compressor are mounted to the cabinet frame with. Although rare, if the screws come loose the compressor will slowly destroy the rubber grommet shock mounts. If you are missing even one grommet (need four) then it will vibrate and rattle. If two screws are loose then it will allow it to vibrate and rattle also.
All bets are off if the compressor is very hot to the touch! Then it probably is the compressor.
Jul 10, 2011 | Whirlpool ED2SHAXM Side by Side...
Noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
May 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Washer is making a loud banging noise..
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 07, 2009 | Kenmore Washing Machines
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Loud banging noise
some popping noise is normal but if it is banging when it stops it needs a new compressor.what has happened is one or more motor mount is broken or weak it could run like this for months or years but it is annoying! if its warranty they have to replace it.
Dec 11, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
481 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
