Frigidaire FWX223LBS5 Won't Spin
I see where the bearing connects to the pulley and it looks like a washer has been spun out. Before it quit spinning there was a metal on metal noise for a few washes and it finally quit spinning. Is it the pulley, washer, or bearing that I would need to replace?
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Posted on Sep 26, 2008
SOURCE: Frigidaire Front load washer FTF2140FS
I HAD THAT TOO I UNPLUNG IT FOR 30 MINTUES AND WHEN PRESS START AND CANCEL TOGETHER AND PLUNG IT BACK ON IT SHOULD BLINK A FEW TIME THEN STOP . IF THIS DOESNT WORK THEN REMOVE IT AND MAKE SURE NOTHING CAME LOSE AND PLUG IT IT AND IF THEN NOTHING HAPPENS SORRY ITS BROKEN REPLACE CONTROL PANNEL.
30-50 $$ NOT MAD AT ALL
Posted on Nov 10, 2008
michiganfan9
  • 179 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0 Makes very loud
if the noise is really loud in the final spin your bearing are starting to go out your washer needs to be rebuilt but it will be cheaper to go buy a new one
Posted on Dec 29, 2008
SOURCE: washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Posted on Apr 15, 2009
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Frigidaire affinity washer error 58
High motor current is recognized in the unit:
1. Remove the belt from the motor and spin the motor pulley. Does the motor spin free? No, replace the motor. Yes, go to step (3). 2. Spin the tub pulley. Does the tub spin free? No, check the tub bearings. Yes, go to step (3). 3. Disconnect the plug from the motor and measure the resistance of the windings (pin 1 to 2, pin 1 to 3, pin 2 to 3). All readings should be between 4 and 6 ohms. If readings are correct, replace the Speed Control Board. If readings are incorrect, replace the motor.
Aug 10, 2012 | Frigidaire Affinity ATF7000E Front Load...
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
Won't spin,changed drive belt, motor pulley and other pulley's are free to move? but belt just stays there with out turning any thing?
can you turn the center transmission pulley in BOTH directions it turns one direction to agaitate and the other to spin if it turns and someone looks in the tub and ever be it slowly it agitates and then turn the pulley the other direction and it doesnt turn the tub bearing is ceased up
Aug 10, 2011 | Frigidaire GLWS1349A Top Load Washer
Washer will not spin
Hi, If it doesnt spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !
May 10, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer has started making a loud humming sound when it is in the spin cycle. Is it a bearing?
Hello astlm529,
Unfortunately it quite likely is a bearing. The rear outer tub bearing in frigidaire especially are common problem`s. It also will likely mean getting a new washer for xmas, the repair is really involved and really expensive.
If you think you are capable, Turn the washer breaker off (it`s best to leave it plugged in, but the power "off" this way the machine is still grounded and the electronic`s are less likely to be damaged) pull the back panel off and inspect the bearing for signs of water leakage and spin the belt off and give the pulley a spin.
You can usually "feel" a grinding bearing if it is bad, but you`ll also hear it without the motor operating this way.
Hope that help`s. If so, please take a second to rate the assistance provided to you here at fixya.
Thank you and good luck.
macmarkus :)
Dec 07, 2009 | Frigidaire Washing Machines
Non-spinning washer
Have you checked the motor? Make sure that the motor is turning properly and also make sure that your belt it not to tight. It should have some give in it. If none of that works then look at the main bearing under the pulley on the drum
Feb 10, 2009 | GE WNSE6280BWW Top Load Washer
sounds like a bad bearing to me
Sep 02, 2007 | Frigidaire FWTR445R
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
