My Toshiba W522 VCR is saying on the TV screen that I need to reset. The error message on the VCR is L2. HELP!
My problem is not solved, but I CANNOT pay for anything as I am on a fixed income. I was just hoping someone would help me and tell me how to fix this myself. Thanks anyway.
Posted on Sep 08, 2008
Can I record off of the tv onto this vcd/dvd toshiba?
Yes,If a VCR/DVD recorder.Not just a VCR/DVD player only.
Nov 08, 2010 | Toshiba W522 VHS VCR
I have a Toshiba VCR w522 and would like to record a program previously recorded from a DVR. Is it possible?
If the vcr has two scarts connect the DVR player to one and select that imput. Watch the program using the the other scart connected to the TV. Press record on the vcr and then start the DVR player going. If it doesn't have two scarts use the front panel jacks to connect the DVR player.
The only time you won't be able to record a program is if somekind of anti-copy system is employed.
Aug 31, 2010 | Toshiba W522 VHS VCR
Problem recording of hd tv with cable box from
Here are a few items to check and how you need to set your recording.
1. Your HD box should have a coax out (or to TV) connection on the back of the box.
2. Connect a coax cable from the back of the HD box to the "RF IN (FROM ANT.)" in the back of the VCR.
3. When you set your VCR to record you need to set it to copy channel 3 and tune the HD box to the channel you want to record.
This should fix your problem...
Good Luck...
Jan 07, 2010 | Toshiba W522 VHS VCR
I have the same preoblem...need manual
Manuals are available for printout in PDF format from the manufacturer, or with a password through devicemanuals.com
As I said in a post to another person, make sure that you're routing the TV signal into or through the VCR. If it's from Cable/Satellite or Digital Converter box, it will simply need to be routed with a coaxial cable, it's a simple fiberoptic cable with a copper or gold prong that you screw onto the back. If you're unable to do this, the box for your broadcast/satellite/cable should have a three-way output, color-coded white, red, and yellow. The red and white are for stereo sound, and the yellow is for the video signal. You can route that output into the three-way input on the back or front of the VCR. This can be technically more challenging, depending on how it needs to have the input setup, for instance needing to be on a specific channel, but routing the cable through the input and output for the VCR is the simple way, and should give you no trouble.
Sep 16, 2009 | Toshiba W522 VHS VCR
I have the toshiba W522 hooked up ok and am agle
I got the info I needed the same day. thinks
Jul 28, 2009 | Toshiba W522 VHS VCR
I have a Toshiba VCR W-522. Is this compatible with Satellite
Why are you getting upset? maybe it is the way you ask the question.
The question I will ask you.......compatable to dish network IN WHAT WAY???
You connect the Dish network to the Toshiba to the TV.
JACKDENNISON;; Everything is compatable if connected in the right way.....
Nov 11, 2008 | Toshiba W522 VHS VCR
Toshiba vc-522
www.toshbia.com go web site dl manel shows u codes toward back pages k
Oct 07, 2008 | Toshiba W522 VHS VCR
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
Can't get vcr to record
Make sure you are giving the VCR a signal.
If using a RF source (cable or antenna), make sure the VCR's tuner is set up for the right type and channels.
When trying to record put the TV's input to the VCR to make sure it is getting what you want.
Jan 17, 2008 | Toshiba W522 VHS VCR
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
