Question about Maxtor Hard Drive
My computer is restarting
Hi my computer is restarting i tried formatt but when it comes to plug and play devices wont go any further and it says line xxxx is corruted or something like that the xxxx stands for the number but i did'nt remember it
Hi there i used a damaged hdd as a salve in another pc and used DREVITALIZE demo program to repair damaged hdd its working just now best regards from llevi
Posted on Sep 11, 2008
    Sergeant:
  • 300 Answers
Did you mean STOP ERROR: ( 0x0000007b ) ?
1. I need to know the model number of the computer.
2. I need to know the operating system you're attempting to install on said computer.
xxxx doesn't tell me anything , looks like a memory error but you'll need to give me the exact error number or error code.
55.00.00 DC Controller error
Replace the DC Controller first, next the Formatter.
The 55.xxxx is a communications error between the DC Controller and the formatter.
Apr 03, 2014 | HP LaserJet M9050 MFP Printer
HP color laserjet error code 49, we turn off the printer when it asks us to but still has an error on it. No clue what is wrong
From the HP Website
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter. Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Jul 15, 2011 | Office Equipment & Supplies
Trying to print a document error 49.4CO2 comes up. What does this mean?
Hi as you will see I have cut this from the manual its not very specific
I hope this is of some help
Ian
Description Recommended action
49.XXXX
PRINTER ERROR
To continue
turn off then on
None A critical firmware error has
abort operation. This type of error
operations. In some cases,
cables, poor connections, or homegrown
applications. On rare
occasions, the formatter is at fault,
which is usually indicated by a
79 Service Error.
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off and then
back on.
3. Try printing a job from a
different software application.
If the job prints, go back to
printing a different file. If the
message appears only with a
certain software application or
print job, contact the software
vendor for assistance.
4. If the message persists with
different software applications
and print jobs, disconnect all
cables to the printer that
connect it to the network or
PC.
5. Turn the printer off.
6. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
7. Remove all EIO devices from
the printer.
8. Turn the printer on.
9. If the error no longer exists,
install each DIMM and EIO
device one at a time, making
sure to turn the printer off and
back on as you install each
device.
10. Replace a DIMM or EIO
device if you determine that it
causes the error.
11. Remember to reconnect all
cables that connect the
printer to the network or
computer.
12. If the error persists, replace
the firmware DIMM.
13. Replace the formatter and
calibrate the printer. See
Calibrate now (HP Color
LaserJet 5500 models only).
Mar 17, 2011 | HP LaserJet 5550 Printer
49, 4c02 error in hp 4250
This is what the result for that error code is:-
ERROR 49.XXXX
Feb 08, 2011 | HP LaserJet 4250dtn Printer
Dear sir, i hv cq40-421tu model. i want to install winxp.But after best tried by me i couldn't install it.so pleaze suggest me the steps n what s/w are needed for it..
This model comes with FREEDOS installed.
When you have it booted up, and insert the XP setup disk, it should give you a menu to test your pc for compatibility.
If it passes, use that same menu to install XP.
Dec 25, 2010 | Compaq Computers & Internet
How can i install a web camera if i don't have an instalation cd? tanks anticipated
If the Webcam is a Plug-n-Play device, all you have to do is to plug it in and the computer should install the driver automatically.
But if it's not a Plug-n-Play device, then you need to download the driver from the web sites.
You may send us the brand and model number of you camera so that we could help you out in finding the driver.
Have a good day!
Dec 05, 2009 | Computers & Internet
I bought geoforce 8400 but when itunes is playing for 20 minutes the sound frezzes and I need to restart the PC
a "GeForce XXXX" is a type of Video Card. It handles images, graphics, games, etc.
This has nothing to do with your Sound.
Do you plug your speakers into small holes near a bunch of other ports? I would guess Yes, as most computers have "integrated sound".
You could try a $10 PCI Sound Card.
Which is where you plug in an expansion card into your computer, and then use that device for outputting sound to speakers. Kinda like how you have a Video Card plugged in below the other ports.
Besides all of this, you could just have a software issue.
Does sound ever stop when playing music or a game outside of iTunes?
You did not say what version of Windows you have.
You did not say what type of computer, ie. Make, Model,.
Such as a Dell, Dimension, 4300.
Please let us know, Thanks!
Sep 07, 2009 | Evga NVIDIA GeForce 8400GS, PCI Express...
ERROR! REFORMAT EXTERNAL MEDIA WITH SIGMATEL FORMATTER. THIS IS WHAT MY RCA S2001 SAYS TO ME? WHAT DO I DO? IVE TRIED DOWNLOADING THE RCA UPDATE DEVICE BUT IT WONT PICK UP THE PLAYER WHEN I PLUG IT INTO MY...
See other solutions posted here about downloading new firmware. Included is holding down the play button when you turn it on and connect it. Click the box to reformat the disc and install ver 1.5 or later of firmware. It wipes the drive but it works. Good luck!
Jun 19, 2009 | RCA JET S2002 MP3 Player
Error 49.420c
first try to upgrade the firmware
second try a cold reset
if this dont work change the formatter
Aug 06, 2008 | HP LaserJet P3005 Printer
Hp 3005dn wont start up all the way
The unit has a bad formatter. The formatter generally comes with memory installed Part# Q7848-31004. Part is super easy to change 6 phillips head screws and 3 cables (ribbon, 6 pin, and 3 or 4 pin power) Remove formatter cover the remove formatter door by opening then lifting up, then unplug the 3 cables then remove the 6 screws. Install is reverse of removal.
Jun 18, 2008 | HP LaserJet P3005n Printer
Maxtor Hard Drive Logo
67 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
