Question about GE JE1540 Microwave Oven
GE Profile Sensor Microwave Oven model JE1660
The microwave oven all of a sudden won't heat anything. We don't get any error messages and can turn it on. It looks and sounds as if it is running, but it doesn't heat anything. Is there anything we can do short of buying a new one? It's only been used about 3 years.
  • 1 more comment
  • llglenns Nov 28, 2008
    The inside light goes on, the timer works the turntable turns, but no heat at all.
  • William Miller
    William Miller May 11, 2010
  • William Miller
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises?
    Is it louder or quieter than usual?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
yettu
Posted on Sep 30, 2010
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: GE PRofile Microwave runs but no heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
  • 8909 Answers
SOURCE: My GE microwave oven (JE1660)
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Oct 31, 2010
  • 472 Answers
SOURCE: I have a GE JE1660
there is a 20 amp fuse inside the unit ,but requires to gain access.. may luck out and it just blew the fuse... normally they are behind the control panel unplug unit and take screws out to gain access hopefully that will fix you up ...if the fuse is good i would suspect you have a failed control board on the unit.... good luck
Posted on Feb 11, 2011
GE microwave JE1660WB001 does not heat makes humming sound
The magnetron has gone and is the heart of the microwave oven, this part is the most expensive to replace, cheaper to buy new in the long run.
Apr 19, 2012 | GE JE1660 Microwave Oven
UNIT DOES NOT HEAT, SLIGHT HUM, BUT TURN TABLE ROTATES, ALL OTHER FUNCTIONS OK
heatman101
Aug 15, 2011 | GE JE1660 Microwave Oven
My GE microwave oven (JE1660) continues to run but has stopped heating, or heats very little.
Hope that helps.
Oct 31, 2010 | GE JE1660 Microwave Oven
My microwave does not heating food
heatman101
jkhg
Aug 13, 2010 | GE JE1660 Microwave Oven
Runs but no heat
heatman101
yud
Jan 12, 2010 | GE JE1660 Microwave Oven
Microwave is on but won't heat.
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
You can now purchase a new microwave for about fifty dollars at walmart so that may be cheaper than having a repair tech work on it.
Aug 20, 2009 | GE JE1540 Microwave Oven
This is a sure sign that the magnatron needs replaced ( This is what heats the food!) replace and all will be good again!
PLEASE rate my response to your question
Thank
You!
Jan 10, 2009 | GE JVM1870 Microwave Oven
GE profile JE1660WB01
may be megnetron or high voltage circuit ..
Sep 29, 2007 | GE JE1660 Microwave Oven
Microwave Ovens Logo
1,213 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
