Question about Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch
Removing the crown
I am trying to remove the crown from my Timex indigo watch so i can replace a digit that had come loose from the face.
So far I have removed the case back. The movement is now loose but is prevented from being taken from the case by the crown shaft/stem.
Can anyone tell me how to remove this?
Thanks,
Percy
  • 2,071 Answers
The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now like your Tag Heuer is pushing, use a needle to push, while pushing the stem lock you pull the crown .That's why ill tell you in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
Regards,
VOTIT
Posted on Sep 08, 2008
What battery does the timex indigo atlantis t
Take your Timex watch to a jeweler, have the back removed, and find out.
Aug 22, 2017 | Timex Watches
How do i remove crown?
hummmmmmm
u need to go experts of watch reper i think its its problem in watch curcuit thats y this happen
& thnx useing fixya
Mar 28, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Remove back of timex indigo watch
If it has screws, remove them. Otherwise, pry off the back.
Sep 12, 2016 | Timex Sport Ironman Indigo Watch - Blue/b...
How do you illuminate A timex indigo
It must be by pushing and holding the crown inword (toward the body of the watch), whereas setting the time would involve pulling it outward.
Aug 28, 2014 | Timex Indiglo Watches
Indigo light doesn't work
It is possible that either that the movement of the watch is not aligned properly after a battery replacement.
Oct 02, 2012 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
The date is advance by one day its a perpetual calendar timex watch
Hi isengard03,
Setting the day on your Timex analog watch is a simple process. Please follow the steps below.
Multi-Function Models
1. Pull the crown on the side of the watch case all the way out. This will be position "C," with position "A" having the crown pushed all the way in and position "B" being pulled out halfway.
2. Turn the crown clockwise until the correct day appears on the small face displaying the day.
3. Press the crown all the way in, to position "A."
Chronograph Models
1. Pull out the crown on the side of the case to position "B." This is halfway out. You will feel a slight click when the crown is in position "B."
2. Turn the crown clockwise until the watch face shows the correct day.
3. Push the crown all the way into position "A" to complete the process.
Hope it helps.
Thank you for using FixYa.
Aug 15, 2011 | Timex T Series Perpetual Calendar #T2M458...
Condensation on inside of face, how do I stop it from happening? and how did it get there in the first place? Watch is less than a year old, Timex indigo WR 30M
mcdevito75, Some watches are waterproof, shockproof, and so on. But, no watch is air proof, Believe it or not air is always in your watch and---all air contains water, hot air, cold air, Heat up air and you seperate the water, the air in your watch gets hot on your wrist then cools when you go outside or when you take off the watch. The condensation you see is the tempersture change of the air in your Timex, Believe it or not. It really can"t be stopped, If you can or have a small watch repir shop remove the back and put in another seal around the back cover this should help. Try to keep your watch at a constant temp.
Jul 03, 2010 | Timex 27191 Wristwatch
I have a timex HRM. The indigo light just stopped working. I've had it for 3 weeks. There is a faint light on the edge, but it doesn't illuminate the face. Everything else works normal. Any ideas?
Check out if your watch has second battery for Indiglo function. It is quite common for Timex watches to have two batteries - one for movement and another for Indiglo.
Jan 21, 2010 | Timex 27191 Wristwatch
Indigo light is not working properly, battery needed?
Timex suggests that you have a watch repair person change your watch batteries. I think it would be a good idea to try and replace the battery, but if that fails to work, contact Timex for advice. If they suggest that you should replace the entire wath, keep the battery. I have no guarantee that any of that would work, though.
Jun 01, 2009 | Timex Watches
Hi, on the back of the movement there should either be a screw or a dimple in line or next to the line of the stem. If a dimple, press in with a pin or similar sturdy tool and gently withdraw the stem. If a screw, only one turn should be enough to release the stem
Nov 13, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch Logo
1,394 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
