We had a paper jam in our Epsom CX7800 printer. We got an error message E-90. We trued turning off and on our printer and it did not help.
  • Evelyn Mezzich Sep 27, 2008
    I have the same problem but in a CX5900...what can I do???
    Genius:
  • 1,550 Answers
You may have a foreign object blocking the path. Move the slide switch to envelope.
Use a piece of heavy stock (backing of a writing pad) put through backwards in the path of the paper output. Be careful of sensors(little black tabs) for the ink head, on either side. If you break them you will have bigger problems.
Lift the scanner assembly while tilting on its back and push the stock to free the foreign object out til you can grab it. Do all this with the printer unplugged.
SAM ANDERSON
Posted on Sep 07, 2008
Epsom printer wont print says paper jam but has no paper jam
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Mar 24, 2011 | Office Equipment & Supplies
Keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
My Epson Stylus CX7800 printer is displaying Error Message 90. In the forums this problem is related to paper getting stuck. In my case, the little ribbon that pulls the printer head back and forth...
Depends upon how "broke" the ribbon is. Sometimes it just pulls out of the connector (friction fit) but if the ribbon is actually damaged, replacement would be in order.
Dec 30, 2017 | Epson Stylus CX7800 All-In-One InkJet...
Error code comes up on my new never Epsom printer reads paper jam
If this is brand new, it needs to have its ink cartridges installed and paper in its tray. It won't be happy until it's completely ready to go.
May 16, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I do'nt see any paper being jammed.
when the message appear? Turn on printer or starting to print? If message appear at beginning turn on printer is caused by "something " slip at paper feeder. But if it appear at start to print, it caused by chip error? Do you use CISS chip?
Jun 25, 2009 | Epson CX7800 Stylus Color All-In-One...
Paper jammed-cleared by pulling paper up& backwards Got a "E-90
Pulling paper out of a printer "backwards" will usually break a gear that is made to feed the paper in one direction.
Epson should be able to sell you the new gear and also when you order it - ask for the installation information or Service Manual to cover the replacement of the broken gear!! It helps a lot in putting the new gear in.
Jun 18, 2009 | Epson CX7800 Stylus Color All-In-One...
Error 90 call for help
Your printer needs the attention of a service technician. Before then, you may try reinstalling your operating system or the printer driver or both.
Jun 18, 2009 | Epson Stylus CX7800 All-In-One InkJet...
I have error code e 90 on my epsom printer
Generally the fix for most "e 90" error messages on Epson printers is to check under the hood of the printer for something that is there and shouldn't be, eg. glue stick, pencil, paper jam, etc. Most e 90 error messages are solved by simply removing something that shouldn't be there. If, in fact, that doesn't fix it, you should try removing the printer catridges and re-setting the printer. If this still does not fix the problem you should try contacting the Epson Customer Service department and try and get a replacement printer, considering this is surely a hardware issue.
May 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson cx7800 error e-04
make sure the ink cover was down tight. Shut down the printer open it up and resecure the ink cover. That has fixed this error in many a case.
Jul 31, 2008 | Epson Stylus CX7800 All-In-One InkJet...
105 people viewed this question
jasbo
jasbo
