Question about D-Link Express EtherNetwork DI-604 Router
Emule Why do I receive a low ID when using eMule through my D-Link router?
    Novelist:
    Scholar:
  • 128 Answers
There are several reasons why this is happening. Most likely the reason is simply because you are behind a router or firewall and the correct ports are not open.
Posted on Feb 16, 2006
I received a complete D-Link Ethernet Broadband Router, Model: DI-604. Included the Installation Disk, and cables etc. My problem is that there are no instructions for installation. I even went on the...
1. There is a emulator on the D-Link site that will walk you through the set up for your model router.
2. When looking up your router model on the site I saw that you model is discontinued but there is some "knowledge base" support for it but no further tech support.
Here is the D link emulator link:
http://support.dlink.com/emulators/di604/
follow the site prompts ( the site is interactive > that is it will respon to your clicking buttons or screen icons.
Sep 20, 2010 | D-Link Computers & Internet
How to forward port to get high ID in emule
Here is how to set up port forwarding for emule: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule.htm If you use emule Plus see here: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule_Plus.htm
Jun 07, 2009 | Linksys WRT160N Wireless Router
Change low Id High ID using eMule
Where are you Santiago, and Emule is still having conflics with its scripts, just change to a another Source, I will pull itup later on tonight and see where the Problem is,...
Aloha
Kahuna
May 28, 2008 | Computers & Internet
Emule Show Low ID on Client Computer
Dear sir/madam,
You can update the servers it may be become fast. Go this site and add all servers (add to emule) click this link, they automatically update the servers.
http://ed2k.2x4u.de/index.html
OR try this
First of all you need to know the IP of the computer that you use with Emule.
Then go to the router configuration:
- Choose "NAT Settings", and "Virtual Server".
1- If it isn't enabled, enable the "Virtual Server".
2- In "Well-Known Applications" choose de option "User defined".
3- Now the crucial part. Under the Virtual Server List, in the "Local IP" you place the IP of your computer (on the example, 192.168.1.2, i.e. my emule computer ip), "Port Range" put 4662 and Protocol TCP. "Protocol nº." stays blank, and in the "description" you can put Emule Rule Nº1.
4- Click ADD, to add the rule to the table.
- Again you make the same passes from 3 to add the second rule:
3- In the "Port Range" you place 4672 instead 4662, and on Protocol you place UDP instead TCP. On "Description" you can place Emule Rule Nº2.
4- Click ADD.
5- After making the 2 rules, click Finish, and on the next screen click on Save&Restart button.
In the next time you start Emule, you can acess to the servers without Low ID.
Don't forget to rate the solution
thanks
Mar 23, 2008 | Computers & Internet
Emule connection problem , DI- 614+ revB router
it sounds like to emule client is hogging all your bandwidth. Try and limiting your emule client to only use 70% of your total bandwidth. If you don't know your internet speed, then go to www.speedtest.com and run a test
Nov 18, 2007 | D-Link AirPlus DI-614+ Wireless Router
No KAD network on emule lo id?
Did you change the standard ports?
This site has excellent instructions:
http://www.portforward.com/
Oct 13, 2007 | NetGear DG834G Router
Emule lowid
I am sorry, but I would not listen to advice that you need to disable your Firewall for it to work!?!
Obviously as the response shows, even with the Firewall disabled it did not work [and would be vulnerable to attack]
There are two possibilities off hand:
  1. You have not taken into account forwarding ports in your Router as well as Software Firewall [if applies to you]
  2. Your ISP may be aware of using the ed2k protocol and try to stop you from using eMule
Remember to use the OBFUSCATION option.
This option in eMule allows you to connect to a server in a way
that masks or 'hides' the ed2k (eMule) protocol
Go To Options > Security
Here you'll tick the "Enable Protocol Obfuscation" box
Remember to only tick the first box under "Protocol Obfuscation"
You should be able to see your 'hidden' status on the right side
of the server window in eMule
If your ISP was in fact interfering, this should help you gain back your ability to use eMule without restriction
Oct 06, 2007 | D-Link DI-707P Router (DSDLDI707P)
Low ID on emule when am using Belkin F5D7230-4 router
You need to find out what port Emule uses for sharing, then enter the port number in you routers Firewall Virtual Servers menu in the settings and enable your pc's ip address to accept inbound connections.
Jan 20, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Low ID on eMule
One more thing re low id on emule - try to choose ports between 10000 and 60000 - many isps block the standard ports that emule users choose, and you will see people saying to choose one over 5000, but I'd chosen ports between 5000 and 10000, and still had no luck until I went over10000.
Most isps don't monitor ports over 10000, so if you still have low id problems even after port forwarding and setting up your firewall, this may be the answer to your problem! (I got this info off portforward.com, and it worked for me)
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
D-Link Express EtherNetwork DI-604 Router Logo
152 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
