Question about Kodak Cameras
I own a kodak easyshare z740.camera turns on but lens does not come. tried new batteries no luck????
  • kryan0001 Sep 09, 2008
    Thank you very much I will try what you suggest, K
  • 6,487 Answers
Turn off the camera for about 5 minutes and make sure the battery is fully charge, if still the same there's a possibility that maybe some dirt get inside the lesn [arts of the camera and needs to be clean or the worse thing is the camera has a mechenical problem already...if camera is still under warranty better tale it to a service center near you....
Hope that helps..........
Posted on Sep 07, 2008
    Sergeant:
  • 264 Answers
There is a small motor which pushes the lenses out. It may have gone bad
  • 89 Answers
The lens might be stuck and needs to be physically repaired. try to bring the camera to a nearest repair center or if it is still in warranty get in touch with the manufacturer of the camera.
hope this helps.
  • 928 Answers
You may try to reset the unit back to factory defaults. You can follow your operation manual regarding this. If that does not work please contact a Kodak service center if your unit is still under warranty,.
  • 3,037 Answers
Any error message pop up? Most likely the gears are jammed and the first thing to try if it isn't under warranty is to bump it on the palm of your hand and see if it will pop out. If it still won't, then you will need to remove the outer panel to get to the gears and see if anything is stuck and try to manually get it to come out. If it doesn't work after manually pulling it out, then the motor is most likely bad or you have a broken connection somewhere. But again, don't try opening it with it in warranty
The lens thing gets stuck wont go in or out and camera shuts down
I may be able to help with your Kodak EasyShare Z740 with a stuck lens.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
May 05, 2010 | Kodak EasyShare Z740 Digital Camera
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Camera turns off when you use telephoto lens camera turns off.
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
I hope that helps.
Apr 21, 2010 | Kodak EasyShare Z740 Digital Camera
My z740 camera will not stay on
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
I hope that helps.
Mar 19, 2010 | Kodak EasyShare Z740 Digital Camera
My camera will not turn on at all and have put in new batteries
I hope that helps.
Dec 28, 2009 | Kodak EasyShare Z740 Digital Camera
Have Kodak easyshare Z740 camera, turn on and goes right back off. Battery seems to be fine tried several charged batteries.
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
May 13, 2009 | Kodak EasyShare Z740 Digital Camera
My camera all of a sudden attempts to come on and then cuts off.
I hope that helps.
Mar 30, 2009 | Kodak EasyShare Z740 Digital Camera
Dropped camera, SD card came out. Took 2 more pictures, camera turned off. Replaced batteries, camera turns on and then back off.
I hope that helps.
Jan 03, 2009 | Kodak EasyShare Z740 Digital Camera
I hope that helps.
Nov 05, 2008 | Kodak EasyShare Z740 Digital Camera
Won't turn on after changing batteries
I hope that helps.
Feb 29, 2008 | Kodak EasyShare Z740 Digital Camera
Cameras Logo
57 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
