Question about Panasonic PT-47WX53 47" Rear Projection HDTV
PT-47WX49E there is a blue wave coming up frpm the bottom of the screen on the lower left corner what could be causeing this and how can i fix it
  • Lonz122156 Jan 04, 2009
    I already replaced my IC's with STK 392-180
    I still have dark wavy lines moving on the screen
    I am going to try to replace all the resistors and caps in the RC circuits around the IC's
  • 2,071 Answers
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Blue wave coming up frpm the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 07, 2008
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Blue haze in lower left corner on screen
if you have any speakers near the screen the magnet may be causing the problem. i had a similar thing happen & when i moved the speaker the problem went away
Jan 02, 2009 | Televison & Video
Red horizontal convergence PT-47WX49E
converge outputs getting tired or limiting resistors opening up. adjusting this incorrectly will make the situation worse keep in mind that overdriving these chips will cause a fold over of your image when you see this carefully adjust in the opisite direction as you may be overheating the outputs
Oct 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sony KP-43HT20 Rear Projection
You have a convergence problem;
Hope this may help;
Regards,
VOTIT
Sep 19, 2008 | Sony KP-46WT520 46" Rear Projection...
Convergance??
Blue,red and yellow wave coming up frpm the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Red, green and blue are out of alignment
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Toshiba TZ50V51 50" Rear Projection...
Blue ghosting on Panasonic PT-47WX49E
your convergence IVs need to be replaced. Its an easy repair if you can solder. you can get the two ICs you need at the following link. they also provide free installation instructions and free on line tech support while youre doing the repair. You need two ICs they are numbers STK392-110. Let me know if I can be of further assistance. I am one of servicemanuals support techs and board rebuilder.
Apr 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
