Question about D-Link Express EtherNetwork DI-604 Router
How do I configure DHCP server on my wireless router?
    Novelist:
    Scholar:
  • 128 Answers
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK. Step 3 Click on the Home tab and then click on DHCP to the left. Note: If you are connecting to a DHCP server, the DHCP server on the wireless router should be set to Disabled. Step 4 By default, DHCP Server is set to Enabled. To disable it, click the Disabled radio button. To enable it, click the Enabled radio button. Step 5 Enter the Starting IP Address and Ending IP Address. To change the lease time, select a value from the drop-down list next to Lease Time. Note: The value for Starting IP Address must be less than the value for Ending IP Address. Step 6 Click on Apply then click Continue to save the settings.
Posted on Feb 16, 2006
NEED HELP TO SETUP MY TRUEMOBILE 2300 ROUTER TO MY DELL LATITUDE D600 LAPTOP. I HAVE BEEN TRYING TO GET WIRELESS CONNECTION. WHAT I DO HAVE , 1300 TRUEMOBILE PC CARD PLUG IN. WHAT I DON'T HAVE IS A...
The Network Key you're probably asking for is on a sticker located, underneath the router. Can you check?
Here's a way to configure your router for your existing network (assuming you already have one) :
If you have an existing network, chances are you have already configured network services on the network. In this case, you would use the router as a pure Access Point to extend the range of your network by allowing more attachment of wireless and wired computers. You MUST also turn off the DHCP server on the router if there is a DHCP server running to avoid IP address conflict.
To configure the router as an Access Point with the DHCP server disabled:
  1. Open your web browser and go to http://my.router, (or the default address http://192.168.2.1.)
  2. Click the Basic Settings tab on the top navigation bar.
  3. Select Access Point Mode.
  4. Click the Next button.
  5. Click OK to dismiss the DHCP disabled message box (The DHCP server will be disabled in Access Point Mode by default).
  6. Click the Advanced Settings tab on the top navigation bar.
  7. Click the Advanced IP Settings tab on the left navigation bar.
  8. Assign an IP address to the Wireless Broadband Router.
    note.gif NOTE: The IP address should be reserved by the DHCP server. The Wireless Broadband Router cannot act as a DHCP client, therefore, it needs a static IP address for its LAN interface.
  9. Click the Submit button.
  10. Click the Save & Restart button.
  11. Note the status bar at the bottom of the screen.
  12. While the Wireless Broadband Router resets, the Power light on the front of the unit blinks.
  13. When your web browser returns to the main page of the Wireless Broadband Route, the device has successfully restarted with the new settings.
    note.gif NOTE: The main page may not return if you have changed IP address of the router in Step 8. To view the main page, type the new IP address of the router in the web browser to access it.
  14. Plug an Ethernet cable from the existing local network into any LAN port on the Wireless Broadband Router.
Jul 01, 2011 | Dell TrueMobile 2300 Wireless Router...
I have a unstable linksys WAG200G what can I do
Converting A Router To A Switch The five steps are:
  1. [Optional] Put a piece of electric tape over the WAN port so it doesn't get used.
  2. Disable the DHCP server.
  3. Change the downstream router's LAN IP.
  4. [Optional] Turn off the wireless radio on the downstream router.
  5. Connect an Ethernet cable from a LAN port on the upstream router to a LAN port on the downstream router.
Step 1: Putting a piece of electric tape over the WAN port isn't necessary. But it is a good way to prevent future problems caused by someone plugging a device into that port.
Step 2: Log into the downstream router, look for the DHCP configuration section, and disable the DHCP server. For example, on a Dlink DI-614+, DHCP server configuration is a menu in the Home configuration section.
Step 3: Change the downstream router's LAN IP to an unused IP in the same subnet as the upstream router. Log into the upstream router and find the DHCP server controls. Figure 3 shows a typical set of DHCP server controls. You can see that 192.168.3.200 - 250 is the range of addresses that will be issued by this router's DHCP server.
You can use any IP address outside (above or below) this range, except for 0 and 255, which are reserved. You also can't use the IP address used by the upstream router. This is usually 1, which in this case is 192.168.3.1. But if you log into your upstream router's admin screens using an IP address with anything other than 1 as the last octet, i.e. XXX.XXX.XXX.1, then just don't use that address.
Thus, a safe LAN IP address for the downstream router that isn't used by the upstream router is an address from 192.168.3.2 to 192.168.3.199. So I assigned my downstream router a LAN IP of 192.168.3.3 (Figure 4).
Step 4: [Wireless routers only] Disable the downstream router's wireless function. It doesn't hurt to unscrew the antennas from the downstream router as well if they are detachable. This gets them out of the way since you aren't using them anymore. Figure 5 shows the wireless disabled for a D-Link DGL-4300.
Step 5: Connect the downstream router. Run an Ethernet cable from a LAN port on the upstream router to a LAN port on the downstream router. The LAN ports are the ports that often grouped together and not labeled as WAN or Internet.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 23, 2011 | Linksys WAG200G Router
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
My PC is connected to this modem/router and works fine. All the laptops in the house show that they are connected but I can't get any websites on any of them. Also, when I connect the laptop with an...
Log in on your router manager http://192.168.x.x and enable DHCP.DHCP provides an automated way to distribute and update IP addresses and other configuration information on a network. A DHCP server provides this information to a DHCP client through the exchange of a series of messages, known as the DHCP conversation or the DHCP transaction. If the DHCP server and DHCP clients are located on different sub-nets, a DHCP relay agent is used to facilitate the conversation.
  1. Connect to your router (by typing 192.168.0.1 or 192.168.1.1 into the URL bar) and log in. Check your user manual or documentation if you do not know the log-in credientials.
  2. 180px-dhcp_router_setup.jpg magnify-clip.png Router Setup tab Make sure you are in the Setup -> Basic Setup category.
  3. 180px-dhcp_router_disabled.jpg magnify-clip.png DHCP is Disabled Scroll down until you see 'DHCP Server' - if it is disabled, select 'Enable'
  4. 180px-dhcp_router_enabled.jpg magnify-clip.png Enable DHCP If you want, you can change the number that the DHCP IP assigning starts. This is optional, and is totally dependant on personal preference.In this picture, the maximum number of DHCP clients is 3. You may need to increase this number according to how many people will need a dynamic IP address on your network. Once the max is reached, no one else can get an address until one expires!
  5. Use the DNS servers provided to you by your ISP, or use the following DNS servers: 205.152.37.254, 205.152.132.235, 205.152.132.23; There are many DNS servers out there. It's best to use your ISP's if possible.
  6. dhcp_router_save.jpg magnify-clip.png Don't forget to save! Scroll down and click 'Save Settings'
  7. Open up the network configurations for the computers on your network (Control Panel -> Network Connections -> Local Area Connection or Wireless Connection) and select 'Obtain IP address automatically'
Dec 09, 2010 | Actiontec GT704WG Wireless Router...
I am trying to install a Netgear router after my switch. I end up having no internet on some of the computers connected to the hub and none on the router. If I configure the router as a dhcp client...
You'll want to configure your router as a dhcp server. Connect the switch to your router's lan port. Connect the remaining devices to a port on the switch. Your wireless access point should have it's dhcp server disabled. You can only have one dhcp server per network. The wireless can get it's address from the router's dhcp and the wireless client devices will get their ip address from the router, as well. If your wireless access point is a router with a wan/broadband port and some switch ports you will want to make sure that you are connecting to your Asus switch via one of the switch ports.
Be sure that your client devices are configured to get their ip address via dhcp and you should be surfing the interweb in no time flat.
Oct 21, 2010 | ASUS GX1008B 10100Mbps Desktop Unmanaged...
Need basic step-by-step instructions on how to install my router.
  3. Reboot the PC.
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
How to set my wrt300n router to use static ip,... i´ve have a problem whit my ps3, and want to use static ip, instead of dhcp(dynamic) should i do it before i do it on my pc and how to do it on the...
You may want to enable the DHCP reservation feature of the router.
What is DHCP Reservation and how do I configure it?
What is DHCP Reservation?
A DHCP reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. Use reservations for the DHCP enabled devices like print and file servers or other application servers which always have the fixed IP address on network.
Step 1: Access the router's web-based setup page. For instructions, click here
Step 2: When the router's web-based setup page appears, click Setup.
Step 3: Click on Basic Setup.
Step 4: Make sure that DHCP Server is Enabled. Then, click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Aug 26, 2009 | Linksys WRT300N Wireless Router
Linksys router vs. hp computer
First of all u should ensure that DHCP server is configured for your required number of computers. this problem seems that you have less clients configured in your DHCP server, existing in router configuration.
Dec 28, 2008 | Linksys Wireless-G WRT54G Router
3CRWER100-75 no DHCP IP on child routers
router 1 (base) router 2 (repeater) router 1 (base) is the network, the SSID is where u get your internet connection set router 2 with same SSID, DHCP on. i advise connecting hardline to make sure both routers are working correctly. once thats verified then go wifi
Jun 30, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Xbox 360
Either the network connection between the 360 and router is not working correctly, or your router is not configured properly for DHCP.
DHCP (Dynamic Host Configuration Protocol) is a protocol that automatically assigns a network address (and some other settings) to your computer....or Xbox in this case. It works like this....when your Xbox connects to the network, it sends out a broadcast packet on the network that looks for a DHCP server. If a DHCP server is present, it responds. Next the Xbox requests its network address and other settings from the DHCP server. Your WGR614 router has a DHCP server function built in, but it may not be enabled. Try reconfiguring the router using the Netgear "Smart Wizard" installation CD and be sure to enable the DHCP capability, if asked.
Jan 10, 2008 | NetGear WGR614 Wireless Router
D-Link Express EtherNetwork DI-604 Router Logo
449 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
