Question about Disney Televison & Video
High school musical tv
We recieved a high school musical lcd tv as a gift, have only used it once. went to use it again, remote doesn't work. except for the number 8. batteries are good, tv is on, but no other buttons, other than the 8 work on the remote.
  • 2,071 Answers
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet for 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Posted on Sep 07, 2008
Hi I have a Aldi bauhn LCD tv and its not recieving the remote signal. I have checked through a camera for the remote control light signal and it works with every button. So that leaves the reciever
Will cost more to fix then a new unit , replace it and try to buy a extended warranty with the new one, most times you can get 3 years after the original warranty runs out.
Apr 04, 2017 | Televison & Video
Why is my LCD TV not powering on after resetting to factory settings?
Kindly study the operation manual and follow instructions for installation from the beginning. You may have to switch off the TV manually, switch off power, remove plug, wait for sometime and retry this.
Jul 30, 2012 | Toshiba Televison & Video
Our pitchure is not bright or clear as was in store
This actually common I worked in electronics for 13 years. Did they tell you that it has to be hooked up to an High Definition source. A digital cable or Sattelite reciever does not mean its HD also using Coaxle cableor composite(yellow,red,white) will not produce a good picture. You need HDMI or Component(RED,Blue,Green for video and red white for audio) to get a high def pic. Also not all station are broadcast in high def. One other thing is even if you have a High Def reciever you need to go into the menu of the reciever where it says display and and make sure its set for 1080i or maybe 1080p(most dont have this option yet) If you are using a normal DVD player and use the yellow red and white once again picture will be poor. Need to use Component or hdmi and again with component you need to set DVD to either 480p and if its upconvert to 1080p
Dec 14, 2010 | Vizio VO47L 47 in. LCD TV
My kids have lost the remote control to there disney high school musical dvd player can i get a replacement from somewhere ???
Try getting a universal remote and find the make of that dvd player and find it with the numbers that come with the universal remote. Good luck.
Sep 04, 2010 | Disney High School Musical DVD Player
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
High school musical dvd player parental control password
ok I have got the manual and for parental options it says
The parental option anebles parents to prevent their children from watching inappropriate material on a dvd. It reads the ratings for programming, then denies access to programmnig if the program's rating meets the limitations you selected. In this case, the user will have to enter a 4 digits security password, then press enter button.
The password in my book is forward button,backward button, forward button, backward button.
tahts the ones with the 2 arrows on.
I hope this helps i need the help line no because my little girls remote does not work with her player.
Dec 30, 2008 | Disney High School Musical DVD Player
Television just went off and won't power back on
my 52 inch 1080 mitisubishi digital tv just went out I recieved it as a gift it was on for two days and i was trying to set channels and instead i locked the front panel tv went out, friend said she no longer have the manual for the tv to reset the code, i bought a universal remote but it's still not coming on plug it up and green light come on and under the on and off button it states timer, gives to blinks and never come onh
Sep 19, 2008 | Televison & Video
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
159 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
