Question about Samsung LN-S4051D 40 in. LCD Television
Menu Trouble I have a couple of problems, 1) the volume indicator is perminantly on the bottom of the screen and I cant remove it 2) I can't turn up the volume with the remote, however I can turn up the volume from the buttons but it goes back to zero when I let the volume button go 3) menu screen only flashes on the screen for 2 seconds and then disappears. TV is only 2 yrs old
  • kevinmd10 Sep 08, 2008
    I have already tried that thanks
    Scholar:
  • 141 Answers
Perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Posted on Sep 07, 2008
  • Steve Froese
    Steve Froese Sep 08, 2008
    Then it must be a problem with the circuit board in the TV
How can I set time and volume?
These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
1. To set Time:
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
2. To set Volume:
On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
Feb 11, 2016 | Tomtom One GPS
I have probl?me code c111 for bizhub 601
let us try out this method lina lina never know that error code will disappear.
1. While pressing the utility/counter bot
1. While pressing the utility/counter bottom, turn ON the power switch SW2.
2. Trouble Reset screen appears.
3. Press the [Trouble Reset] key.
4. Enter Service Mode Stop>0>0>Stop>0>1
5. When CE password has been set, enter it.
6. Service Mode Menu Screen appears
7. Conduct necessary operations and turn OFF the SW2 after completions.ton, turn ON the power switch SW2.
Jan 26, 2016 | Office Equipment & Supplies
How do i stop flashing display mode on kd r856 bt car audio
Try this
1. Press and hold the MENU button
2. Turn the volume to select DEMO and press the volume to enter the sub menu.
3. Turn the volume to select DEMO OFF and press the volume to set.
4. Press MENU to exit.
Feb 23, 2015 | JVC Car Audio & Video
My new TomTom volumn is too low. How do I adjust it?
The menu button has combo list of all functionality to device.
The procedures of manupulating the device functionality includes;
1. a touch screen button indicating menu would display a list with which to reset system functions; an example of adjustable features include brighteness, contrast, color and volume.
2. a device functionalities are acquired on the menu button, though could include sub menu buttons with lists manipulatable.
3. Locate the volume button after pressing menu, submenu, while perusing th e function options until volume is diplayed.
4. A volume display indication for touch screen devices observable as a long stretch bar with manipulation features describable.
5.A volume display on the tom tom gps could be situated on either vertically or horizontally.
6. A volume bar is manipulate by pressing directly on to the device area of the bar observed and attempting to drag an indication arrow from a graded direction. For example, lowering the volume requires pressign and moving the arrow towards the numerical grades of fewer numbers.
Note: your situation of requirign volumn increase is achived by dragging the arrows towards the numerical grades of higer numnbers to make possible more directional audibility.
For technical assistance, refer to the user guide on how to maniplate volume functionities.
Dec 02, 2010 | GPS
2 questions 1 i got a old computer and i have a problem getting on different sites now they tell me to upgrade to browser IE8 AND I'VE TRIED I'M NEW SO I CANT FIGURE IT OUT -QUESTION 2 HOW DO I TURN MY...
Download Mozilla Firefox instead of IE8
Sound
1. Check volume control on speaker
2. Right click on volume icon at bottom right of screen. Use slider to increase volume
3. Check that speaker connection is in the correct port (usually green in color)
Oct 15, 2010 | Computers & Internet
I have a iphone 8GB and is on silent seen nd i don't know how to remove it on silent? pls can u tell me want to do?
To enable/disable the silent feature on an iPhone, simply look to the left-side of the phone. There will be 2 buttons there:
1. A small, switch that goes left/right. 2. A longer longer that can be pressed up/down.
Button #1 is the silent toggle switch. Moving it to the left enables silent-mode; to the right disables silent-mode.
Button #2 is the volume adjustment button which will raise the volume if pressed up and decrease the volume if pressed down.
Note: If you press the volume bottom down all the way, the handset will mute itself. When using the volume button, a volume indicator will appear on-screen to indicate how loud/quiet the phone is. If there are no white bars present on the indicator scale, then the iPhone is muted. Press up on the volume button a few times to increase the volume and disable mute.
Aug 11, 2010 | Cell Phones
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
I do not hear sound from my headphone
1.check your headphone
2.remove headphone and play music
3.do you hear sound on your system..then your headphone has problem.
4. if you cant hear sound on your system.
5. check volume control
6.goto start,program,accessories,entertainmen,volume controller
7.after doing this, the problem remain same.. then do the following steps....
1. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click on the sound,volume and controller
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
**** after doing this.. you can check the follwoing steps for trouble free ******
7. double click system device
8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
9. then select Action from the menu bar on the top and select scan for hardware changes
10. then it will start scanning your new hardware and ask for the installation drivers.
Jun 28, 2009 | Computers & Internet
Indicator lights stay on perminently
its the signal switch on the colunm NOT the hazard switch
Apr 13, 2009 | 2004 Audi A6
TV TROUBLESHOOT
step 1 check the ABL, step 2 check the junggel ic
Oct 26, 2007 | Akira HPT5001D Television
Samsung LN-S4051D 40 in. LCD Television Logo
555 people viewed this question
Henry  Thomas
Henry Thomas
