Question about Samsung Cell Phones
Voice sounds garbled. Phone is over a year old. Do I need new battery.
Voicemail picks up too soon and New voice mail message always on
Check call waiting feature with mobile provider on number of rings to voice mail. Many problems repaired with booting phone (holding on/off button down till screen logo comes on & removing charged battery cleaning contact connections on phone and battery with DRY SYnthetic NOT cotton cloth ideally clean battery with alcohol swab let dry before returning to phone
Aug 07, 2009 | Vtech DS6111 Cordless Phone
Phone sounds like going underwater, buzz noise when headset in
it sounds like u have fitted a cheap double phone line adapter try removing same and see if sound improves
Jul 21, 2009 | Panasonic KX-TG2431 Cordless Phone
Nuvi 350 Garbled voice
How is the other sound? Like MP3 sound? Is it garbled there? Try using headphones. If the sound is good there, then your internal speaker is bad.
Email me at ks3r at sharc dot net if you are interested in me fixing this for you.
- Jim
Sep 10, 2008 | Garmin Touch Screen GPS Receiver
Distorted voices
if it sounds garbled it may be due to digital communication. most scanners cannot recieve the digital communication. that is why you hear a garbled inaudible sound from it.
Jun 18, 2008 | Uniden BCD396T Handheld Scanner
Voice mail garbled
I have run into this problem in the past. Power off the telephone system. Power switch is on the top (back) right of the cabinet or you can unplug it from the wall. Be carefull , if your memory battery is bad, you will lose programming on the phones.
cycling power to the system has fixed this in the past for me, if this doesnt work you may have to replace the vm card in the system.
Mar 12, 2008 | Lucent PARTNER18 Corded Phone
Answering machine replay is garbled
Your handset battery will have no effect on the answering machine audio, providing your regular audio is fine (its fine when you make a phone call right?), I will assume yes. I have seen this problem in these models, and your problem lies in your base station, and the only fix you can attempt is to go into base programming and delete as much as you can out of the memory, greetings, old messages, etc.. Power down, then power back up again. Call in and leave a message. See if it sounds better through the handset or the speaker on the base when you play it back. If its garbled both ways (reviewing through the handset or on the speaker base) , then your problem is in your base memory. If it is just garbled on your handset, then it may be a radio module problem with the base, either way it probably needs to go in for repair. I don't know if Panasonic still repairs that model, but if you google Panasonic cordless telephone repair, you will find someone. Good Luck, CG
Jan 11, 2008 | Panasonic KX TC1731 Cordless Phone
Custom voices
You cannot customize the voices on this, or any other Garmin product of which I am aware. The Tom Tom Go 720 will allow you to record your own (or someone else's) voice on the unit (50 different phrases). However, any unit with the Text-to-Speech feature (which is what gives you the spoken street names) utilizes computerized voices to put the words together, which is why some sound "garbled." No unit does this better at this time. Tom Tom's pronunciations are, in my opinion, worse if anything (Branch instead of Bridge when abbreviated "Br", Crossing Island Parkway instead of Cross Island Parkway, etc.).
Dec 30, 2007 | Garmin StreetPilot c550 GPS Receiver
Cell Phones Logo
546 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
