Hello
What is the Brand name and Model number of your TV. Without it, how can I post a solution to your problem? Send these to me by Fixya please.
Is there any loss of height to the bottom side of the screen? You have only reported thet there is some less height to to top only. I've to confirm this, That is why I asks you. Plese note that is there is the same gap at the bottom of the screen also.
Hello=You haven't given me the details I asked you. Anyway, I posts this solution condsiderng that the black bar is on the top side of your TV screen. This is due to weak capacitors in the vertical output section circuit of your TV. Just open your TV, locate this section and replace all the capcitors [may be 5or 6 of them] with new ones of same capacity marked on it. When replacing these electrolytic capacitors, make sure their polarity. Electrolytic capcitors have both powitive and negative polarity. It will be marked on its body. Mark this side when you unsolder the capacitor out one by one and replace it. If the black bar is at the bottom of the screen also, check the solder terminals of the vertical output IC. Resolder all the solder terminals of that IV by applying a little more solder without making any solder bridge short in between adjecent terminals. If this does not help you, replace the vertcial output IC also with same type and number. These parts can be bought from most of the elcetronic sparepart shops at your town. Won't cost mor too. OK
I'm sorry that the TV is displaying 1.5" black strip on the top of the screen. Please let me know the model # of the TV so that I can give the specific instructions to resolve the issue.
Thanks for understanding.
Your set has either a bad driver board or more likely a bad plasma panel.
My Sharp TV is model# 32US50B and serial # 303828619
I have a Sharp TV model# 32US50B, serial # 303828619, it has a black strip across the top of the screen @1.5 inches wide. Is there an adjustment to fix this problem?
Itis a Sharp TV model# 32US50B
