Question about Xerox Phaser 7700 Laser Printer
Xerox 7700 intermittant banding on a diagonal black only
I have a issue with black printing. The black toner is intermitant on a page. The missing or very light areas are banding on a page and run at a diagnal at about 1 inch a part. If I print the solid color test pages, all colors are ok except black. I replaced the black toner, no help. I swaped the print cartagre with another color howerer the problem stayed with the black color.
  • gigawatt Sep 10, 2008
    I already cleaned the laser. Where is the developer housing? I would lke to inspect and/or replace it. Thanks
    President:
  • 2,072 Answers
You most likely have a bad black developer housing.
You can try removing the waste bottle and using that bla\ck stick inside the cover to clean the laser ****.
But it sounds like the developer housing has failed.
Posted on Sep 08, 2008
Yellow band on page
It is probably the yellow Image Unit (the toner fits into it)
Dec 01, 2011 | Xerox Phaser 7400/DXF Laser Printer
Erratic black fusing
I'm not real sure about how the software separates the colors, but I believe there's a way to choose a color as all colors combined to make black, or simple black.
I'm not sure if I'm making any sense, but if the printer is using all the colors to layer up and make black, then it would be a pretty thick coating and that might cause it to flake off.
Oct 30, 2007 | Xerox Phaser 7700 Laser Printer
Fuser seems to be intermittant near center of page
you problem is in the fuser assy. just replace if you have spare.. the problem is that the plastic hinge on your fuser assy roller that is use to control the gap of the rolle.. it is allready worn out the parts allready slips on the plastic hinge, intermitent problem occur of fuse and un fuse print out
Jun 22, 2010 | Xerox Phaser 7300DN Laser Printer
There are large black bands on all my pages when
This is generally an issue with the drum rather thatn the toner cartridge. To fix such an issue, generally one must pull out the toner and the drum, then clean the toner powder from both the drum and the inside of the printer. The lines are usually caused by a buildup of excess toner powder caught within the machine.
//halfs
May 25, 2010 | OKI C5200n Laser Printer
Xerox Phaser 7700 printing Black line across bottom of every page
The line could be caused by contamination on the black laser lens. Try using the cleaning wand located in the front door to clean the lens. You will need to remove the waste toner container to access the wand slots. If that does not solve the problem, the black developer housing may need to be replaced. Refurbished parts at: http://www.lpscomputer.com/p-3064-116-1111-00-black-developer.aspx
Apr 23, 2010 | Xerox Phaser 7700 Laser Printer
Black Prints
The toner might be bad, because the old cartridge is working fine.
Jul 31, 2009 | Xerox DocuPrint P12 Laser Printer
Our HP 7700 printer
Looks like a toner issue . Try replacing the toner.
Jun 12, 2009 | Xerox Phaser 7700 Laser Printer
Xerox XC1020 White Bands running across copied page 4" apart
The metering blades in those cartridges go bad and do not allow the ink to get to the page. Look at the front of the toner cartridge, is should be a solid consistent black all the way across, if its streaky, not consistent all the way across replace the toner.
The other problem could be a dirty laser. If replacing the toner doesnt work let me know, I will tell you how to remove and clean the laser.
Jan 16, 2009 | Xerox CopyCentre C20 Black and White...
Phaser 7700 steaks on Magenta, sometimes yellow.
Each color has its own laser. Use the cleaning wand in the front door to clean the lens covers for each color. You will need to remove the waste toner cartridge in front of the the slots to do this. If that does not cure the problem, you will need to replace the developer housings for the colors that are streaking. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
and parts purchased at: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
Dec 12, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
505 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
