Question about Texas Instruments TI-84 Plus Calculator
My keys arent working at all
I can turn it on but thats all. It cant be turn off and the keys are dead how can i fix this?
  • 3 more comments
  • Anonymous Sep 12, 2008
    Sameee probleeeem and i only have it for like 2 weeks used it 3 times didnt connect it to pc :S
  • snacks tasty Sep 13, 2008
    This is water damage. I have it too. I ticks me off and it won't work. I have no clue how to fix it but it is water damage.
  • gamecalchack Sep 20, 2008
    Same thing, but my keys are all messed up, so when I enter a 5, then a load of asterisks pop up on the screen
  • Anonymous Oct 02, 2008
    Will turn on - blinking cursor - no other keys work - recognized by TI connect
  • jennah16 Oct 23, 2008
    So the calculator has 5 columns of buttons, and only my FAR LEFT column doesn't work (with the exception of the On/Off and 2nd keys) So everything above the On/Off key and below the 2nd key in the far left column don't work. I have no idea what is wrong and water damage seems almost impossible because I have no idea when it has ever even come in contact with water.
  • 32 Answers
I found a solution to my problem. I think water got into my I/O port and it shorted it. The way to fix it was to blow really hard into the I/O port or use compresed air.
Posted on Sep 13, 2008
Why won't my ignition turn on my 1998 dodge caravan
More details please, is enough gas? Is the starter running? And more...
Nov 25, 2014 | 1998 Dodge Caravan
My 2005 cadillac cts turns on but has the car lock symbol on along with the traction control light and the temp and gas gauges arent working. Then when I try to turn my key off it doesnt release my key....
try unhooking you're positive battery cable wile the car is running then turn ignition off and put positive cable back on. if the problem is electrical this should reset it. could also be a fuse or a splayed wire.
Oct 27, 2013 | 2003 Cadillac CTS
Gsxr 1000 k1 system dead
you imobilzer may not be reading you key check for overide sequence and try with imobilizer disarmed
hope this helps
Aug 09, 2009 | 2001 Suzuki GSX-R 1000
Running problems
the pick up coil and module work together to give spark and pulse the injectors pull distributor and rebuild ,which all the 2.8 eng, are like this,,, also check to see if knock sensor is pluged up
Jul 03, 2009 | 1991 Chevrolet Camaro
Logitech keyboard,s keys are not working
Modern keypads arent as great as old ones where each key had its own switch and you could just open and fix it. new keypads have everything interconnected inside them. The only thing to do is buy a replacement, But if you really love this one keypad, you could try and clean it out with a blower and make sure the keys that are failing arent failing because of dust or unwanted debri.
Jun 20, 2009 | Logitech Keyboards&Mouses: Delux Plus...
Sound work with Headset but on speaker no sound otherwise
one way what u can try is have your headset when u turn on the psp after switching off. then once again try restarting without it. now u might have sound if your speakers arent dead. else am sure ur speakers or connection to it is dead. else try wit different UMDs. again one more is try updating the psp to a newer version. if u have a software problem which causes the sound off then that might fix it.
May 05, 2009 | Sony PlayStation Portable (PSP) Console
Creative Zen Vision M frozen on the start up screen
Hey guys, I've had the same problem for over 2 years. Guess what? I fixed it today!! It is indeed a hard drive issue. I recommend following a guide to disassemble your zen. (Remember, this is only if you dont have any other choice) When you disconnect your hard drive, plug it right back in there pushing hard on it to make sure it is connected completely. IF that does not work, this is the final resort.
I did this and it worked. Normally you arent supposed to ever do this to any kind of hard drive. But why not? since it is already broken. lightlyish hit it a few times, and take the end of a screw driver and stick it in the hole on the end of the hd and pry it loose a tad. you arent trying to pop it open, just givve it a little breathing room. Worked for me, normally it shouldnt. But no one seems to be sharing anything so hopefully this helps someone some time in the future.
Mar 30, 2009 | Creative Labs ZEN Vision:M Digital Media...
My Truck wont shift out of park and my brake lights arent working
there a little switch on the shifter to stop it from going into gear with out the brake on .eather theres no power or switch is bad. it under the dash at the shifter .good luck
Mar 14, 2009 | 1995 Ford F350
Keys not working
You need to reset the phone, email me at staryblaze@aol.com so i can ask you some more questions about what it is doing. Really the best and easy way to fix it, go to your cell provider and they will fix it for you.
Mar 02, 2008 | Motorola Mobility L6 Cellular Phone
Texas Instruments TI-84 Plus Calculator Logo
234 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
