Question about Fisher Paykel EcoSmart GWL15
A penny fell underneath the agitator & went underneath inside the tub
I was washing clothes, when they finished i reached in to get them out. I saw a penny in the bottom of the tub when i reached for it it went up under the agitator, when i removed it to get the penny it wasn't there it has fallen underneath the agitator inside the tub. I have not used the washer because i am afraid it will hurt it..how can i get the penny out? or will it hurt the machine if it says in there.
    Genius:
  • 1,028 Answers
Remove 2 rubber plugs on each side of lid remove the screws underneath lift top up remove the plactic ring around tub top by pulling up on clips along top edge remove the spring on left attached to ring lift ring off remove agitator again lift inner tub up and out ..when reinstalling inner tub be sure it drops completely in so the center gear drops in place
Posted on Sep 07, 2008
Kenmore Model 110.2234 top loading wash machine About a year old It is so loud on spin cycle we cant hear each other talk in the other room with laundry door shut What is the problem?
Possible bearing failure but if only a year old, it should be under warranty. Check around the spin bowl for any foreign objects sticking through the tub. Perhaps a bra wire or nail , screw etc or something has come out and stuck in the tub.
Nov 20, 2016 | Kenmore Washing Machines
Balancing problems with the spin cycle
Redistribute clothes in the tub. It may take several tries. If this doesn't resolve try it with just water and no clothes load. Still doesnt resolve, there may be an issue at the upper bearing load carrying or bearing adjustment surface. A slim possibility there is something under the spinner tub, but that would interfere with the tub reaching spinout speed.
May 25, 2015 | Admiral Washing Machines
Agitator getting clothes wrapped underneath bottom not releasing
Could be a Major issue! Unless the agitator will unhook from inside the tub. See if the Very Top of the agitator unscrews. If it does then the agitator should come up. The motor is directly connected to or part of the agitator shaft.
Nov 29, 2013 | Washing Machines
What is the agitator
The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
Sep 26, 2011 | Whirlpool Washing Machines
I have a GE washing machine model # WCSR2090DAWW and today I went to put a load of clothes washing. It filled the tub up with water like normal and then went into soak mode. The problem starts when it...
Possible that some item of clothing is jamming up the drive to the tub. The burning smell are the motor windings reacting to the excess of electricity flowing thru them before they burn out.
Apr 02, 2017 | GE Appliances 3.5 cu. ft. King Size...
Ken more wot stop filling but think i got it want to make sure
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Mar 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer leaves trash on clothes when finished. has been doing this for some time now. some of the particles resemble dried tree leaves.
It sounds as if there is a soap buildup in possibly a couple of places and it is coming loose then ending up on your clothing. If you changed brands of soap this can happen also. The soap buildup can be under and inside the agitator. It can manifest itself in large calcium type flakes in the washer when it finally breaks down and you see it. You can remove the agitator by opeing the top of your agitator and removing the retaining biolt then lifting out the agitator. Use a putty knife and scrape off the inside of the wash tub under the agitator. Also take the agitator either outside or to the bathtub depending on weather and scrub it clean on the bottom and on the inside of the agitator. If after all of this you still have that same material show up you may have to remove the wash tub itself and clean the outer tub with a putty knife. There is a special tool that locks into the 4 slots of the tub nut used to remove the tub nut. You can buy it at most appliance part centers. Tell them you need a tub nut removal tool for a kenmore / whirlpool top loading machine and they will walk back and get you one straight away. Good luck andI I hope this resolves your problem.
Jan 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
After the clothes finish completely the water is leaking from the bottom of the washing machine
Do not but Do not under any circumstances continue using a leaking machine.
HighVoltage +Water=Electrocution
Get a Techo to check it out and survive to tell the tale.
Oct 24, 2009 | Roper RAS8445KQ Top Load Washer
Why do we keep getting pennies in the drain pump? We search our clothes carefully but apparently it is only pennies. Is there a possible broken screen?
no broken screen when washer goes in to spin the pennies move up the inner tub to the outer tub to the pump inlet remove pennies from close
Oct 14, 2009 | Maytag Bravos MTW6600T Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
291 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
