Question about Maytag Dryers
I am looking for a tint trap for a Maytag dryer model #DE303 Series 07 Serial # 189625 XJ
  • 374 Answers
Try partsstore.com as they do have your part in stock. I would phone them to make sure their website information is correct. If for some reason this did not help you you can try the chat portion of this website
Posted on Sep 09, 2008
Have a maytag heavy duty dryer model lde512 07 series and it is not getting clothes all the way dry what could be wrong
Problem might be with your washer not spinning them dry enough..or your vent is plugged up with lint
May 06, 2017 | Maytag Dryers
My kenmore dryer 70s series wont start
send the model number,open the door and look around the opening where you put the clothes in,you'll see a tag with model and serial number,just need model number.
Mar 18, 2013 | Kenmore Dryers
My maytag dryer,model no.DE303 makes a loude clank-a-d-clank noise as the barrel rotates. Sometimes the sound will change and smooth out, only to get lound again. How do I fix this? It still turns and drys...
This is likely caused by a worn-out drum roller. There are two of these which support the back of the drum and allow it to turn smoothly. Replacing these involves taking the front panels off and removing the drum.
Dec 15, 2011 | Maytag Dryers
I have a maytag dryer model number de303. was working fine, now it buzzes but the dryer won't turn on?
Hi
When the dryer wont start it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset. If the fuse tests fine then it can be the main board that is bad and is due for a repair.
Hope this will help...
Dec 30, 2010 | Dryers
Maytag SE1000 Series 07 dryer wont heat
You need to have 220-240 or so volta ACROSS the two terminals on the element...the 125 can feed across and can be the same leg on both sides...
Check out this tip also..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 22, 2010 | Dryers
Maytag DE303 dryer installing the drum belt
No don't lube the idler pulley replace it. There are videos at www.appliancehelponline.com/servicemanual.html that can walk you thru the disassembly and also on replacing the belt. You can also enter in your model # for diagrams and illustrations.
Apr 09, 2010 | Maytag Dryers
How do i OPEN a maytag model DE303 dryer? Not just the door (duh), but the actual dryer itself, for repairs...
remove the two screws down by your toes . in front panel //pull out at bottom till panel is 45 deg . and the two top cli[ps will release . carefull to not brake the door & wires . remove wires and set side . hey your in .. now what do you want to do .. feed back pls .. mm
Dec 17, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
I have a model DE303 series 07 maytag electric dryer and it is not heating up?i am experienced in electrical
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jul 06, 2009 | Maytag Dryers
Maytag dryer won't keep running
poss the starter relay.
Mar 16, 2008 | Dryers
Dryers Logo
53 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
