Question about Pure Digital Flip Video Ultra Camcorder
Thanks mastersaint, follow-up....
The first trick of rebooting and turn on did not work. The problem is not localized because I tried this on three different computers so far. All unrecognized.
Now, the real trick may lie in your link: http://www.hat.net/geeky/node/221
Following the steps....
I proceeded to "Remove Hidden Devices" via DOS, then proceeded to device manager, now I ONLY uninstalled the "Unknown devices" under the USB branch. as shown in the photo below. I thought the instructions only meant those.,
Am I required to delete all those greyed our ones included the "Generic USB Device"? Is tis safe? This was not 100% clear in the instructions of that page
  • PattyFerrant Dec 26, 2008
    Yes, I have this same problem except I know the device works on my laptop... As soon as I plug into usb on laptop, the device software window opens up. but my pc does not recognize this same device. I have 2 (one for each kid) and neither one seems to be recognized on the pc.
  • 928 Answers
Hi Letian,
If you have tried this on all 3 computers then i would definitely suggest you return the unit. The USB unrecognized works only for a computer that it was working before but the unit must be working on another computer. The solution at my link is for Ghost devices that cause the specific problem. If you tried the device on another computer and you have never plugged the device on that computer then the unit is either defective or nearing that. While it is still under warranty I suggest return it as it will certainly give you problems in the future.
mastersaintx
Posted on Sep 07, 2008
  • Thomas Lim
    Thomas Lim Sep 25, 2008
    As for the device if it is under warranty I do not suggest you do anything further to try to fix it as it is under warranty. if it is not under warranty kindly message me.
Gold star dehumidifier turns on collects water. Buttons not working. Cannot change the humidity high or low or timer
Check your manual for a reboot or override procedure. If there is none,then try unplugging for about three minutes the replug. If no luck,next try unplugging, leave overnight. Then plug in see if that works. Sometimes static electricity can build up, this will help to dissipate it. Of course, it could be a bad control panel. If so you may be able to get a replacement from the company or a local electronic store. Good luck.
Nov 22, 2014 | Dehumidifiers
How to reformat Nokia E63
Hello there are two tricks that can format your E63.First type *#7370# when your phone is in stand-by mode (normal) and enter security code.Secondly,Format by press and hold three keys i.e. *(star),Green(call),3(three button)until your phone reboot in normal mode and power on the phone.Thanks for visiting fixya
Jun 20, 2012 | Nokia Cell Phones
My n95 is not working because of locked code that i forgot.what should i do?
sir, you have to restore your mobile, please follow the steps.
1. Switch off your phone...
2. Remove SIM card & memory chip...
3. Now press & hold keys - 3,*,call green) ...
4. Then without leaving these three buttons press power button...
5. Formatting task will be started...
6. Remember its a very rare trick....
Dec 28, 2010 | Nokia N95 Cellular Phone
Unlock security code nokia n95 8Gb
If you have forgot your Nokia N95 8GB's security code then i will recommend you to do following:
  • Enter 00000 or 12345 as pass code first.
  • If above codes wont work then you will have to RESET your phone.Resetting your phone will end up in loss of all DATA that you have on your cell.Every thing will be restored to factory configurations no Security code will be their.
  • Soft reset code *#7370#
    Hard reset code *#7780#
    If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
    + Turn off the mobile device.
    + Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
    + While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
You shall check following link too:
NOKIA N95 Tips and Tricks
Dec 06, 2009 | Nokia N95 Cellular Phone
I cant open my Iphone after rebooting
Some tricks to try;
1.) Try pushing and holding the power and home buttons for 25 seconds.
2.) Try connecting to iTunes and do a full restore?
a. If you are experiencing the same, try this:
b. Hold buttons sleep + home until iPhone turns off;
c. Open iTunes;
d. Hold home button and plug the phone to your computer. The phone will turn on and the iTunes + Arrow + cable screen will appear.
e. ITunes will recover you phone from unsuccessful recovery process.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 17, 2009 | Apple iPhone Smartphone
N73 reformat
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Jan 27, 2009 | Nokia N73 Cellular Phone
Cant log on
Tried posting a couple of times before, but guess they didn't show up, so will try again.
Just for grins and giggles, try the following and see if it doesn't do the trick.
1-remove and reseat the hard drive and try again.
2-remove and reseat the memory module(s) and try again.
3-remove the battery & power cord and let set for awhile. At least for 1/2 hour and maybe as long as over night.
Try these as a first step and let me know how you come out.
Thanks, Ron
Dec 09, 2008 | Computers & Internet
Cannot sync between Treo750 and Laptop anymore
Based on the things that you have said the first suggestion that i could give is to try another computer install the program and see if it will sync with the Treo. That will help you isolate the probelm.
Nov 17, 2008 | Palm Treo 750 Smartphone
Temporary connection loss
The issue is now resolved. I found the solution by trawling through the 2wire troubleshooting website articles...
Here's how I fixed mine:
1) open the Management and Diagnostic Console by entering 192.168.1.254/mdc in the address line in your web browser.
2) click on 'Configure' under the heading 'Local Network' on the left column.
3) change the 'set DHCP lease time' to 999hours (instead of 24hours) - this stops the router from resetting itself every day.
4) click on 'wireless' under 'Local Network' in the left column again.
5) change the 'power setting' to 10 - ie maximum - this boosts the wireless signal, which means it's less likely to be dropped.
& that did the trick. Been working continuously now for the last month and a half! :))
Nov 03, 2007 | 2wire HomePortal 1800HG Router...
Pure Digital Flip Video Ultra Camcorder Logo
199 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
sharky633
sharky633
tomikles
Level 1 Expert
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
