Question about Video Game Consoles & Games
MY PS2 JUST STAYS ON THE BROWSER SCREAN. IT DOSNT GIVE ME A DISK READ ERROR. IVE TAKEN IT APART AND CLEANED IT. ON START UP THE LASER COMES ON AND THE DISK SPINS BUT AFTER ABOUT 15 SECONDS THE DISK STOPS, THE LASER TURNS OFF, AND IT JUST STAYS ON THAT BROWSER MENU.....
  • 19,396 Answers
Try cleaning the lens with isopropyl alcohol and cotton.
If this does not help the lens may be faulty, in this case you will need to replace the lens pickup.
Posted on Sep 07, 2008
  • Ginko
    Ginko Sep 07, 2008
    Check if the motor is working and if CD ir running. If disk spins , and lens pickup moves, motor, belt and mechanics are ok.
    If lens pickup does not move at all check mechanics.
    Lens is most likely cause for the fault.
    Check also your guaranty terms.
  • 89 Answers
The lens might be misaligned and needs to be aligned by a technician or the lens might need to be replaced already.
Disc read error
you could try cleaning the laser using meths on a cotton bud
Jul 12, 2008 | Sony PlayStation 2 (PS2) Compact System...
Will play CD's but not DVD's or Games
You have to take the box apart and clean the lens.Ok !
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
PS2 not reading disks
Your lazer lense has bit the dust. Depending on your model type the first gen systems lazers are very easy to replace. The later versions sony made it harder to replace. You can find out what model you have by looking at the back of your PS2 then you can either call sony or go to there website and find out what generation PS2 you have. Then go from there. Hope this helps
May 08, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
Sounds like a disk read error alright. Try replacing the laser eye device in the PS2. I know a good place with pretty low costing parts for PS2s. RichsPSXParts. If not the laser eye try the ribbon cable between the hard drive and the laser eye. Those I'd think be the most obvious first checks. I'm not 100% on it since every one I know whos PS2 does that wont let me look at it instead the throw it away. Such a waste.
Apr 10, 2008 | Sony PlayStation 2 Slimline Console
Dvd not reading
dont go to browser screen.wait fo some time.it will load automatically.if you had touchead the lens , dont do it anymore.if you want more sugesstions then fixya!!!
Mar 17, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
I had that same problem, Just purchase a cd lens cleaner and it worked.
Dec 10, 2007 | Sony PlayStation 2 (PS2) Compact System...
My ps2 wont read any discs but it plays music discs and cd's
Hi Cozza,
Open the console up, and remove the cover over the Cd drive. Clean the lens of the Laser with a Q-tip lightly dampened with Rubbing alcohol. Use the dry tip of the Q-tip to dry the lens, look to see if you left any lint, and make sure the lens of clean.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
Playstation 2 Disc Read Error
After extensive research on this subject and working on several Playstation II systems. I found out the reason your system will play only blue disks and not silver is a alignment problem with the laser. It could be tilted or set to high or low. The quickest solution is to call Sony and get a new laser with the shuttle. If i am not mistaken it cost 50.00 and just go to the playstation site select support and it will explain in full detail how to take your system apart and replace the laser and shuttle.
Sep 16, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Disc Read Error
You should buy a replacement dvd drive for the ps2 , for about 25.00 USD on ebay, it is easy to install considering you already have taken apart the ps2
Aug 17, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
