Hi, you can try to remove by turning off the printer and turning on when the cartridge holder moves in center unplug the printer into the power outlet you can freely move the cartridge when the cartridge is not locked at the right side.
Hello jgw_cansdale,
Welcome to Fixya.com!
If the Ink light () is flashing that means one or more of your ink cartridge is low on ink, and if it's steady it means one or more is out of ink. For Epson printers, there are lots of ways to identify whether your printer is out or low on ink. For today let's just stick with the printer itself.\
Remember: A flashing means LOW ON INK, and a steady
1. Open the scanner bed by lifting it up just like opening a brief case. By doing this you should now be able to see the carrier area this is the area were the ink carrier or ink holder moves left and right,
2. Press the Ink button. Now remember flashing means LOW and steady means OUT of ink.
If the Ink light is flashing, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is low on ink. pressing it again will point to another if you have multiple cartridges that are running low, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
If the Ink light is steady, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is out of ink. pressing it again will point to another if you have multiple cartridges that are out of ink, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
Regards,
Deathschythe33
