Question about Maytag Microwave Ovens
Microwave turns on and rotates but won"t heat the food. humming noise also.
  • Maytag Master
  • 9,098 Answers
With these symptoms,you probably have a shorted high voltage rectifier diode or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We\'re happy to help you with free advice and we\'d appreciate your thoughtful rating of our answer.
Posted on Sep 09, 2008
Microwave will not heat, but will turn on. Clock and Timer still work. Turntable turns. Making a loud humming noise and light flickers
This clearly indicates a bad magnetron, "heats food" in most cases it is cheaper to replace the microwave oven than have it repaired, since the magnetron is the heart of the unit.
Mar 01, 2012 | Microwave Ovens
Makes a humming noise wont heat
If its making a humming noise, that means the diode is bad and should be replaced. Once replaced the microwave will begin to heat again.
Feb 11, 2011 | Kenmore 62622 Microwave Oven
The microwave makes a loud "hum or buzz" noise but will not heat up the food My microwave is running and sounds like it is working but will not heat up anything.
Hi, Your hi-voltage system has gone bad. The noise you are hearing is the hi-voltage transformer. This has taken the magnetron which does the heating out. The magnetron has a 5 year warranty on it, the rest of these parts only have a year on them. Contact your nearest repair center. Thanks,
Jan 17, 2011 | Microwave Ovens
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave seems to work but does not heat food
OK, you may have a damaged thermostat or, the Magnetron may be damaged as well. you can test each device with a meter(ohm,volt).
replace any parts that dose not register.
Jun 03, 2009 | Panasonic Microwave Ovens
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
