Question about DeLonghi EO1238 Toaster Oven with Convection Cooking
No power. Where is the fuse?
    Champion:
  • 242 Answers
There is usually a thermal fuse in line with the power wire. Check for one inside a teflon mesh wire in line with the power. Inside of the toaster over of course.
Posted on Sep 17, 2008
Breville bov800xl wont turn on. Reset option?.
If the screen turns on and looks like it's working but there is no heat, then the problem is the thermal fuse. It takes reassembly and a $5 replacement fuse. I replaced mine with one of the same specifications and it lasted a month. I replaced it again with one that trips at a 10 degrees higher setting and it's been good for a couple of years now.
Feb 25, 2015 | Breville BOV800XL 1800 Watts Toaster Oven...
I have a Brevelle 800 toaster oven that starts, but does not heat up. What part needs replacing?
There is a thermal fuse that breaks power to the heating elements if it gets too hot (somewhere around 173 C. I replaced mine with an identically rated fuse and it was good for a week until I tried to cook twice in succession. I then replaced the fuse with one that trips at around 190C and it's been good for 4 months now. The fuse costs about $6 on ebay (shipping included) and takes about an hour to replace.
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
It wont turn on model T0131SWD!!!!!!!
follow this charter troubleshooting and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#1#ixzz2gUR97IFo
Oct 01, 2013 | Black & Decker Toaster Ovens
My Breville BOV800XL doesn't have any power.
My BOV800XL did the same thing. Of the three parts you mention the thermal fuse is by far the easiest to test and in my opinion the most likely to go out first. Check it with a meter. If you have trouble locating it read the FixYa solution for "The Breville BOV650XL will not power on." Check it for continuity like you would any fuse.
I found replacement parts at ereplacementparts.com. The thermal fuse assembly was $23 when I checked. Or you could just replace the actual fuse portion of the assembly with a comporable fuse such as http://www.mcmelectronics.com/product/NTE8213. Basically you need a 216*C thermal fuse. These can be had for less than $2 plus shipping. Buy a few just in case.
I just ordered my fuses today so I can't report on the success of my repair, but I am confident the new fuse will solve the problem.
Aug 30, 2012 | Breville BOV800XL 1800 Watts Toaster Oven...
I had the same problem with my Breville B0V650XL. It worked fine at breakfast, then wouldn't turn on the next time I tried to use it. Judging by the comments on this site, this appears be a common problem with this and many other Breville products.
I fixed my toaster oven by replacing the thermal fuse assembly. This part costs $4.39 on ereplacementparts.com. It's a shame that an expensive toaster oven is rendered useless by the failure of such a cheap part.
Replacing the thermal fuse itself is very simple - you'll need a small wiring nut and a phillips screw driver. Unfortunately, getting to the part requires removing the oven cover and about 40 screws. A long, magentic scewdriver is essential for parts of this job. It took me about 1 hour to fix my oven - two minutes to replace the fuse and the rest of the time to remove and replace the oven cover.
Feb 25, 2012 | Breville BOV650XL 1800 Watts Toaster Oven...
Need to check fuse or change out elements
disconnect first the unit from power supply. pull out the fuse and check for the continuity of the terminals with an ohm meter, if there is no continuity,, replace the fuse. for heater, remove one heater terminal connection and check for the resistance reading.if no resistance read, replace the heater. ALWAYS DISCONNECT THE UNIT FROM POWER SOURCE BEFORE DOING THESE.
Mar 27, 2011 | Wolfgang Puck BTOBR0040 Toaster Oven with...
No power
Having same problem. I found bad fuse/thermal coupling(I think)
Looked at solution for bad fuse but need more info on part#.
Will continue.
May 14, 2010 | KitchenAid KCO1005OB 1400 Watts Toaster...
Stopped Working!
check the switch or thermal fuse, if it has.
Aug 29, 2009 | Black & Decker TRO603 Toast-R-Oven Toaster...
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
My KA KCO100508B blew its thermal fuse after 3 years. I found a replacemnt close to 206 centigrade for $2.60 at Appliance Parts Warehouse near my home in Smyrna, GA. Know what to ask for when you enter APW. They don't like selling potential fire hazards to novice repairpersons!
Mar 05, 2009 | Toaster Ovens
Blown fuse
You need to go to your local Harbor Freight Tools and pick up a security tool kit for $9.99 so you'll get the bits required to remove the special screws. You need to remove all the screws around the outer edge of rear and then pull the white rubber plugs out of feet and remove the screws from feet. Then the entire cover lifts off of unit. That exposes where the power cord enters the back of unit. You'll see a smaller black wire leaving that area going over to the timer knob. Before the wire gets to the timer knob, there is a sleve covering the wire. If you'll cut the zip tie holding all the wires together, you can slide the sleve (mine is red) backwards toward where the power wire comes into unit. That will expose the inline fuse that is blown. You will need to call Delonghi to order the wire. It is pressure fitted on. You should be able to pull the connectors lose by hand on each end. Simple fix!!
Dec 28, 2007 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
DeLonghi EO1238 Toaster Oven with Convection Cooking Logo
489 people viewed this question
Top DeLonghi Toaster Ovens Experts
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
