Question about Sony KP-51WS500 51" Rear Projection Television
Screen turns blue
After having the tv on for about two min. the screen turns blue.
  • Christopher Oct 02, 2008
    My SONY is 4 years old KP-51WS500. Picture ok for a minute, then goes blue.
See the "faint red lines" solution...
Posted on Oct 20, 2008
Try taking off the back of the tv. Once you have done that turn your tv on and see if the red lamp goes out, if it does then that is your problem...
Posted on Oct 15, 2008
It seems as if many models of sony happen to have the same problems!!!
Posted on Oct 01, 2008
Blue screen after power surge
tv goes blue everyday afte use.....i always have to turn off tv to get tv.......after 5 min.....
Jan 31, 2013 | Olevia LT37HVS 37 in. LCD HDTV
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Screen tuens blue them tv turns off
NOT GOOD NEWS... IT SOUNDS LIKE YOUR BLUE CRT IS SHORTED. THE ORIGINAL PART IS N.L.A.(NO LONGER AVAILABLE) THEY DO MAKE A GENERIC REPLACEMENT, BUT I DON'T THINK THEY ARE AS GOOD AS O.E.M.
YOU CAN TAKE OFF FRONT OF T.V. AND ADJUST THE SCREEN DOWN ON THE FOCUS BLOCK. IT IS THE BLACK BOX WITH 6 ADJ. ON IT 3 ARE FOCUS. 3 ARE SCREEN . TURN THE BLUE ALL THE WAY DOWN , THEN WITH THE BACK OF A PLASTIC OR RUBBER SCREWDRIVER HANDEL YOU CAN TAP ON THE NECK OF THE CRT, NOT TO HARD. SOME TIMES YOU CAN CLEAR THE SHORT OUT OF THE CTR. IF THIS WORKS LET THE SET WARM UP FOR 10-20 MIN. THEN TURN THE COLOR ALL THE WAR OFF, THEN SET THE BLUE LEVER UNTIL YOU HAVE A GOOD BLACK AND WHITE PICTURE. BE CAREFUL NOT TO TURN IT UP YOU CAN DAMAGE THE CTR IF THE LEVEL IS TO HIGH. ERROR 8 IS A.K.B. ERROR THAT MEANS THE CRT'S ARE DRAWING TO MUCH CURRENT.
DON...
Nov 12, 2007 | Sony KP-51WS510 51" Rear Projection...
Re above
I have the same problem on my 32 in,after having the Tv on for about 3 hours Tv turns off, every 10-20 min. tv turns off. very upset with DELL. , blue light stays on.... what can i do to fix promblem.......
Oct 28, 2007 | Dell W3201C 32 in. LCD Television
Blue screen of death
What you Have Is a Main RCA Failure you Have a Cathode to Grid Short In your Picture Tube,The Tube shorts and Tells the Miainboard to shut Down...Good Luck
Jul 13, 2007 | RCA TruFlat 27F520T 27" TV
Sony KP-51WS500 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
