Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Replacing Smart Mix knob
I am obtaining a replacement Smart Mix knob (broken knob). When re-installing, you say that the Smart Mix valve should be in the down position and knob in Water Only position. But which direction does the horizontal "protrusion" on the top of the valve stem face?
  • firescout Sep 08, 2008
    Oh, ok. I think I understand the re-assembly better. I should remove the valve piston from the valve body, install it in the underside of the Smart Mix knob (in the Water Only position), then lower the top cover back on the unit. The valve piston should then go directly into the valve body as the cover goes on. Yes?
    President:
  • 1,673 Answers
The knob itself will only go in one way, What I was talking about is when you put the top cover back on, the knob should be in the water only position. This way the piston (on the bottom of the knob) will go into the slot correctly.
Posted on Sep 08, 2008
  • Lauren Junge
    Lauren Junge Sep 08, 2008
    Yes, just make sure the knob is in the water only position when you push the top down.
Smart Mix selector
I figured it out,since you nor Bissell was of no help. It turns out to be quite easy.
Jul 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat
The piston needs to be on the bottom of the smart mix valve, and the knob needs to be in the water position when you put the top cover back in place.
Jul 13, 2008 | Bissell 1699 ProHeat Clear View Upright...
Smartmix bottle
The cap and insert at the bottom of the bottle may need to be replaced, or you could have a problem with the smart mix asm. You would have to remove the top cover to get to it. Does the smart mix knob stop where it is supposed to or does it go all of the way around, if it does, then the stop on the knob is broken.
May 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7920 ProHeat Problems--No solution spray
Is the smart mix valve turning and stopping where is is supposed to, if it turns all of the way around, then it is broken inside the top cover. Try replacing the smart mix bottle insert and cap asm part #2101795 . Make sure that the rubber gasket is on the valeve asm. at thebottom of the smart mix bottle. If not, it has to be on the valve.
May 19, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Removing the top of the 7901-1 Bissell Proheat
Unscrew the cap for the flow indicator, remove the 6 screws, the top will come off. When you put the top back on, make sure the piston is hooked on the smart mix knob(underneath the top cover) set the smart mix valve in the wtaer only setting, then put the top back on. Turn the smart mix valve to make sure it is turning like it should, then re-install the 6 screws and the flow indicator parts. (don't over tighten the screws)
May 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
I purchased a Pro Heat self propelled Bissell rug cleaner model 7950 from Target wherehouse on 4-26-06. I used it once and all was fine. The next time that I went to use it the smart mix for the cleaning...
I assume that it is spraying water? Is the smart mix knob turning freely from one point to the end? If not then there is a problem with the smart mix asm. With liquid in the soap bottle, push the valve in to see if liquid comes out ok, couild be that the valve is bad. Is the seal on the valve at the bottom of the bottle, it has to be on that and not just sitting in the hole. You might try running a mix of water and vinegar thru it, maybe it is clogged up.
Apr 14, 2008 | Vacuums
Broken Smart Mix Dial-How to replace
You will have to remove the top, the knob screws on but has a stop tab. Is the plastic below the knob ok, if not then you need to replace the top cover. After you replace the knob, then put the piston on from underneath, have it set to water only selection, then put the top cover back on.
Mar 04, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
Smart mix valve reassebly and alignment
Have the piston on the screw threads, put the knob on the water only setting, then after the piston is on, turn slightly so it doesn't come off, just before you put the housing all of the way down, turn the knob back to the water only setting and then push the top all of the way down. Turn the knob back and froth and if it turns smoothly, then it should be ok. If you put the top down and it is straight, the piston will go into the slot ok.
Feb 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell proheat pro tech model 7901-3 smart mix dial and valve assembly
Turn the knob to the water only, put the piston on the bottom of the knob then turn it slightly so it doesn't fall off, Start to put the cover on, when it is straight, turn the knob to the water only selection and push the top all the way down. The piston should have gone into the hole and the knob should turn easily.
Nov 14, 2007 | Vacuums
Rt. elevator arm replacement
Take off the top cover, then you can replace the elevators, they come both sides in a package, part #2000010. When you replace the top cover, check all tubes to make sure they are routed right so as to not pinch one when the cover is locked down. Also there is a piston that attaches to the bottom of the smart mix valve and that the smart mix knob is on the water setting, then put cover back in place and don't over tighten the screw.
Jun 13, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
651 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
