Re: Mac book moving real slow what needs to be done?
If you prefer a more
efficient way to resolve, try an all-in-one Mac speed up software as it
can help resolve all issues in just a few clicks. Learn more:
http://www.howtospeedupmac.com/
Question edited for clarity and toss in some CAPS.
It is a well known issue.
If you find your Mac is running slowly, there are a number of potential causes that you can check. Your computer's startup disk may not have enough free disk space. To make disk space available, you can move files to another disk or an external storage device, then delete files you no longer need on the startup disk.
Reddit · r/mac50+ comments · 2 years ago
It looks like all the apps Adobe has running in the background has caused my Mac to slow. ... M1 Pro MacBook pro and it gets slow but restarting ...
Avasthttps://www.avast.com > ... > Performance > Speed
Jun 20, 2023 - Your Mac might be slow because of an outdated operating system or a full hard disk - especially if you have an older model Mac. If your Mac is ...
ok, it simple, first, follow the steps.
check your contact book must be empty if not , delete it all contact from your mac.
check your iphone if it has all the contacts.
sync with itunes n select from info that you want to replace the contacts in the macbook.
your done.
I think you mean adding email address to your account (importing email address), If you've set up the account properly, then there's not much difficultly, just follow the instructions below
1. Open the Address Book application.
2. Choose Import from the File menu.
3. Navigate to the file that you exported from your previous application and select it from the list of files. Tip: if you cannot select the file, the 4. Open button will not pulsate. This may indicate that the file is not in a format that Address Book can read.
5. Click Open.
Your addresses (contacts) are now available for use in Address Book and all Mac OS X applications that work with Address Book.
On the other hand if you are importing addresses from previous version, the procedure is little different. Do let me know if you can't do with this. Good luck
perhaps you can export you're adress book and calendar in a file from the PC. Then ask ical and adress book on the mac to import it. (you launch the program and go to files/import)
