Question about Olympus SP-560 UZ Digital Camera
Trouble with card cover
Says the card cover is open, but it isn't
I found the same problem posted by another member. Using a bobby pin instead of a matchstick as suggested, (only because I did not have a matchstick) I put one end of it into the hole beside the memory slot and tripped the stuck trigger. Worked perfectly. THANK YOU!
Posted on Sep 08, 2008
What is the P0440 trouble code on a 97 850 volvo non turbo
Code is for the evap system which vents gas fumes from the tank.
Could be anything from a bad gas cap to a leak in the vent system.
Jun 27, 2012 | Volvo 850 Cars & Trucks
Verizon wireless lg env2 vx9100 make put a sim
Verizon phones (unless global which the env2 isn't) do not support sim cards. If you are talking about a micro sd card. It goes in under the cover on the right side for the phone. Hope this helped
May 23, 2012 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Overheating of graphics card while playing games
  • Clogged fan
The main device responsible for maintaining a constant temperature of your video card is the fan present in the processor. If this isn't functioning efficiently it's quite obvious that it would result in your video card overheating. If you don't regularly clean your computer, it could be highly likely that your fan is clogged with dust.
This is one of the simplest causes of your video card overheating which can be fixed by simply cleaning your fan, preferably using a blower.
  • Broken fan
A follow up of the previous point, in some cases your fan maybe malfunctioning or stopped working altogether. This could simply be diagnosed by switching on your computer with its cover open and checking if the fan is functioning. If it doesn't happen to be working, you have your answer.
  • Overclocking
Pushing your CPU to its limits by overclocking can cause your video card to overheat. This can seem fairly obvious too as if you find your video card overheating and if you've recently overclocked your CPU, it would explain it.
  • Faulty Drivers
This is a rare cause, but depending on your video card's brand a badly developed driver could also cause your video card to overheat. If you use an unusual video card with questionable reputation this could be the issue.
  • Inefficient Airflow
While your fan maybe perfectly in tact and working, the location of your fan also matters. If there isn't sufficient air flow to your video card it can also cause it to overheat.
Those are typically the 5 main reasons to your video card overheating. If you have any other points in your mind, feel free to share them below.
May 09, 2012 | ASUS GeForce GT240 1G DDR3 550Mhz
Have two codes 1490 and 1489 what are they and how do i fix them
It's most likely low speed fan control relay circuit trouble.
There are separate relays and control circuits for high and low speed for the fans. This way if one messes up the other one should still work. Relays are in relay/fuse block under the hood. There is a diagram under the relay box cover that shows the function of each relay. The relays just plug in.
1489 = High Speed Fan CTRL Relay Circuit - An open or shorted condition detected in the control
circuit of the high speed radiator fan control relay.
1490 = Low Speed Fan CTRL Relay Circuit - An open or shorted condition detected in control circuit of
the low speed radiator fan control relay.
Either the relays are gone or the connector isn't plugged in, probably the connector if both the low and high circuit is out.
May 06, 2011 | 1998 Dodge Intrepid
I accidentally drop my camera and the card cover cracked and i cannot closed it beacause the cover broke. i tried duplicating a cover but it always says Card-Cover Open. Is there a parts for this so i can...
It may be more trouble than it's worth to purchase a replacement. Simply use the duplicate cover that you fabricated. But to get your camera to work, you'll need to find some way to push in the door's safety pin switch seen in the lower left corner of the below picture. Try wedging a small piece of paper (spitball) in there to close the switch. That should allow the camera to work with your duplicate cover.
Mar 23, 2011 | Olympus FE-320 Digital Camera
Can't turn on computer
you may try:
1)open cover take out all exterior devices like cdrom/HD/PCI card/AGPcard then power on, go next if nothing change.
2)open cover see any fan turning when power on , if nothing run, check biger power supply plug pin(Ps-on and 5Vsb)all at 5V are OK, less than 3V or nothing is power supply box damage. change new power box to test. still same trouble go next
2)open cover you can see a LED light on on the motherboard
and check power on button is working well(switch).
3) check all biger capacitor top, any one bulged shows motherboard DC damage and need to repair by PC specialist.
4) nothing change above, you have to change motherboard.
Dec 21, 2008 | HP Computers & Internet
Shutter having trouble opening and closing.
Hey SleepyFairy,
What it sounds like is that something sticky has gotten into the lens cover mechanism, and the only way to fix that is to have it repaired. If this camera is less that a year old it is most likely still covered under manufacturers warranty, and you should have it looked at by an authorized service technician to get it fixed.
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Trouble shooting
its very simple!!!
> Take out the back cover and the battery
> W580i as its SIM card slot in the top right corner...
> once you see the SIM card just push it in with your thumb nail for the SIM to pop out...
FixYa...
Dont forget to rate the solution!!!
Apr 06, 2008 | Sony Ericsson w580i Cellular Phone
Olympus FE-140
Yes I had the same problem, however, where is says "push to eject," it means to push the the memory card down and it will eject. You pushed down the latch for the plastic door cover. Try pushing something into the hole so the camera thinks the door is closed. I am still having trouble with mine. Hope this helps alittle.
Sep 16, 2007 | Olympus FE-140 Digital Camera
Several problems
I am having the same problem. I think it might have to do with the memory card being corrupted. I am going to buy another one on ebay and go from there. If anyone knows what is going on with this please post it. Thanks.
Apr 05, 2007 | Olympus Camedia C-350 Digital Camera
Olympus SP-560 UZ Digital Camera Logo
56 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
