Question about Cuisinart DLC-5 Food Processor
Have a very hard time to snap the top on the food processor same to take the bowl out
Thank you for the follow up
the only way to solve my problem for an older model cuisinart basic is to buy at Le centre du rasoir a new bowl and cover for the model DLC 10 that should fit
have a good day
Posted on Sep 09, 2008
Cleaning magimix handle
Magimix Food Processor and Bad Customer Service
fussfreeflavours.com/the-tale-of-the-magimix-and-bad-customer-service/
Jan 12, 2012 - Magimix food processor review - the exorbitant cost of replacement ...time to find out how to clean the internal part of my Magimix 5200 handle.
magimix compact clean handle Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your magimix compact clean handle question. Get free help, tips & support from top experts on magimix compact clean handle related issues.
Food processor - Magimix
www.magimix.uk.com/page/faq/Food-processor/CS-5200-XL/
Magimix UK : FAQ Frenquently asked questions - Food processor. ... direction until the locking tab engages the top of the bowl handle. ... Never exceed the quantities recommended for your food processor model in the instructions for use.
Amazon.co.uk: Customer Discussions: Food processor bowl to
Jan 01, 2016 | Magimix Food Processors
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Jan 03, 2015 | KitchenAid Food Processors
Need the main food processor with the handle
My handle snapped off (cheap cheap construction). Now model is discontinued. If you can still lock the bowl into place, use the tip of a knife to press down the little switch in the opening where the handle used to be. I've been using mine for 6 months this way after KitchenShop stiffed me on a replacement bowl.
Oct 28, 2013 | Viking VFP12 12 Cups Food Processor
I cannot remove the top from the base
I don't know what brand food processor this is. However, are you saying that the bowl will not rotate to release? It's normally just a matter of twisting the bowl (probably anti clockwise when viewed from the top) in order to release it.
Apr 12, 2010 | Cuisinart DLC-5 Food Processor
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
The plastic ? bowl of the processor is stuck
With the food processor I have it will not allow you to remove the bowl unless the top is off.Try take the top off or putting it on.Then remove it from the processor.
Sep 22, 2008 | KitchenAid KFP670 Ultra Power Food...
Euro-Pro EP91 Quad-Blade 6 Won't Start
My wife was given this unit from an elderly gentleman that was done trying to make it work.
I just fixed the same problem as above. Note - I do not have a manual for this unit.
True above about the bowl cover being locked in position but found the key to make it work is also the white lid to the left of the bowl cover. I was locking and unlocking this white lid with no results. Then I removed the bowl cover and found the white lid cover was loose and easily removed this white lid to inspect inside ( why this cover removes I have no clue).
Anyway I was able to snap the white cover firmly on and turn counter clockwise to lock in place ( six o’clock position), then after putting the bowl cover back on and snapping in place it works.
Note - I do not need to turn the white lid cover to install or remove the clear bowl cover, this could be because it looks like one of the clear tabs might be broken on the locking area of the clear bowl cover. If you have two tabs the same shape on the bowl cover you may need twist the white lid clockwise to install and remove the bowl cover and counter clockwise to lock in place so the unit works, but now that my white lid is snapped firmly in place it hardly moves with the force of both hands trying to turn it.
Hope this helps someone.
Good Luck !
Dan L. P.
Jan 05, 2008 | Euro-Pro EP91 Quad-Blade Food Processor
It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
Wont run
If you try the instructions below, and the motor test fails, you can send it in to Cuisinart for a trade-in, but the trade-in will be just as expensive as getting a new food processor (unless your product has an extra-long motor warranty):
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Sep 16, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-5 Food Processor Logo
105 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
