Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
Jan 19, 2009 - 14 posts - 11 authors
I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Yes. Rear-proj.with 3 picture tubes. These, like most newer tvs have self-checks that shut the tv off if the fault could worsen problems for the TV (such as damage picture tubes.) or it's not able to put a picture up.
After it shuts off, you can press menu and input/device together for 5 secs, and it will flash a 2-digit code (such as "23" or "24", etc.)(vertical or horizontal error.) Though you will need to call a repair shop for repair. It's usually better if they are Mits. factory authorized, as they'll likely have more exper. on Mits.
Like stated before--May be another bad blub, especially if you used a generic or Neolux one. A phillips bulb WILL work right. Mits sets do NOT like generic bulbs !!
Look inside front panel under RHS picture tube for leaked fluid. If you see a puddle on signal board, take tv to street - it is unrepairable then. The coolant is poisionous. If that looks ok, then make sure you're using original Mits. remote. Hope this helps.
Turn the tv on now,have pictures only flashes a few sec. than pictures dies,than have sound left only?Yes,than tv have those 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Capacitors going bad on your DM or FMT board. Very difficult to replace, but Mits does a rebuild on the chassis. I recommend talking to your Mits service center and getting the rebuild done.
Okay try to distinguish if the three blinks is 1 pause then 2 blinks or 2blinks pause 1 blink. As the set will only blink a two digit code 12 meaning no error detected and 21 meaning the set is hutdown due to xray protection.
