Question about Kenmore 62602 Electric Dryer
Electric Kenmore Dryer
Worked and then pushed the start button for the next load and nothing. Unscrewed control panel, took out start switch and it was obvious that it had blown. It was clear plastic and could see the works.
Bought replacement switch, installed it and machine does not start. Drum light on, buzzer works when I push start button...this tells me the switch is good but maybe something else is bad.
I am just heading back to work from a workig vacation and need my dryer. I am $40+ dollars in the hole and still not fixed.
Please suggest something I haven't tried...oh, did check the door safety, works.
Thanks
    Genius:
  • 1,028 Answers
Possible bad timer but first ck thermal fuse ..if top mount filter remove back fuse is small white object on blower housing ..if door mount filter remove bottom panel remove lint screen remove 2 screws each side holing lint screen housing in place fuse is behind it ..if fuse cks good suspect timer ..
Posted on Sep 07, 2008
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
I have a kenmore electric dryer it worked fine i dryed a load of clothes in it and went to dry another load and it wont turn on i set the knob to tempature to dry my next load and push the start button and...
This may be a thermal overload switch which is probably located underneath the top of the dryer. When you find it, bypass it to see if that is the problem. If so, replace it for about 10-12 dollars. Check the breakers first, then the connections in the back to see if they are secure.
Dec 29, 2008 | Kenmore 659 Electric Dryer
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
My Push Start Relay or Control Knob is not starting the Dryer
is this the even heat model? if it is you need a new control board on the back of the timer area and might as well buy a couple relays the black ones with 4 wires in them. one is for the pts and the other is a heater relay both are the same part
Feb 07, 2007 | Kenmore 62622 Electric Dryer
Kenmore 62602 Electric Dryer Logo
88 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
