Ifyou have compressed the hard disk drive using the Compress drive to save disk space option under the Propertiesmenu for your hard disk drive and have performed a non-destructive recovery ora system recovery, the following error message may appear:
NTLDR is compressed. Press CRTL-ALT-DEL to restart.
This error message is resolved byfollowing these steps:
1.Insert the Windows XP CD drive onthe computer and restart the computer.
2.Press F12 when the computer firststarts, then select CD-ROM, click any key to boot into windows startup.
3.When you get to the install windowsXP screen:
4.Press Rto repair the Windows XP installation using Recovery Console.
5.Enter the appropriate number for theWINDOWS installation, for example, the WINDOWS installation could be listed as 3:C:\WINDOWS or 3: D:\WINDOWS .
6.If prompted, enter yourAdministrator password and press Enter . If there is no password, justpress Enter .
7.At the prompt, if the WINDOWSinstallation you selected in Step 4 was C:\WINDOWS, type:
cdc:\
Or, if theWINDOWS installation you selected in Step 4 was D:\WINDOWS, type:
cdd:\
8.At the prompt, type:
attrib-c ntldr
and thenpress Enter .
9.At the prompt, type: exit
10.Press the Enter key and immediately remove all discs or diskettes from thecomputer to allow the computer to restart.
The startup files are corrupted.You need to put the windows disk in the DVD and make the computer boot off that when it starts up. Booting off the DVD may need to be set in the BIOS if the machine does not do it automatically.
When the window comes up you select install windows.
Second option is repair my computer. Then follow the prompts.
First check to see if you have a floppy disk in your floppy drive, if so remove it.
Second check if you have a CD disk in the CD/DVD drive, if so remove it.
If there are no disc in the drives, then the ntldr file is missing or corrupted and needs to be replaced. Please follow these instructions :-
best thing to do if you can get one is a propper install disk and then follow these instructions..
1. Start the Recovery Console. If you do not have the Recovery Console installed, start it from the Windows Xp compact disc (CD). To do this, follow these steps:
a. Insert the Windows XP CD and restart the computer. If prompted, select any options required to boot from the CD.
b. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
c. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the recovery console.
d. When prompted, type the Administrator password.
2. At the command prompt, type "cd \" (without the quotation marks), and then press ENTER.
3. Type "ren ntldr ntldr.old" (without the quotation marks), and then press ENTER.
4. Type "map" (without the quotation marks), and then press ENTER.
5. Note the drive letter assigned to the CD-ROM drive that contains the Windows XP CD. It is displayed in a format similar to the following: D: \Device\CdRom0
6. Type "expand <drive>\i386\ntldr._" (without the quotation marks) (where <drive> is the drive letter of the CD-ROM drive that contains the Windows XP CD), and then press ENTER. For example:
Expand d:\i386\ntldr._ <ENTER>
Note the underscore character after the "."
The following message appears: ntldr, 1 file(s) expanded.
7. Type "exit" (without the quotation marks). The computer restarts.
8. Remove the Windows XP CD and start the computer normally.
Reference number: CH000465
NTLDR is Missing.
Issue:NTLDR is Missing. Related errors:
Below are the full error messages that may be seen when the
computer is booting.
NTLDR is Missing Press any key to restart
Boot: Couldn't find NTLDR Please insert another disk
NTLDR is missing Press Ctrl Alt Del to Restart
Cause:
Computer is booting from a
non-bootable source.
Computer hard disk drive is not
properly setup in BIOS.
Corrupt NTLDR and/or
NTDETECT.COM file.
Misconfiguration with the
boot.ini file.
Attempting to upgrade from a Windows 95, 98, or ME computer
that is using FAT32.
New hard disk drive being added.
Corrupt boot sector / master
boot record.
Seriously corrupted version of
Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard
disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand: http://www.computerhope.com/issues/ch000465.htm
You're in a real dilemma without an XP CD (it doesn't have to be yours). What you need to do is to repair the installation. I'm assuming you intentionally compressed your hard drive.
What you need to do is to boot to the CD and then, when prompted, press "R" to recover you build. It will take you to a shelled DOS prompt. From there run CHKDSK on your boot drive and it should see the compressed NTLDR and fix it.
